Killer wobble Everything is shaking
- Dutchjimny
- Visitor
I know what the deathwobble is around 70kmh but today the death wobble turned into something different i guess.. i was driving 60kmh when the car started shaking the steeringwheel shaked and the gearknob shaked harder than ever i could only brake and drive slow..
The car is an 2000 jimny with the Ora 3" Liftkit
Please help!
- Dutchjimny
- Visitor
I cant use the car at all.. In the beginning 500km there were no problems with the lift
- Thank you received: 153
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
Gary
- darthloachie
- Visitor
- Adamski
- Visitor
MysticRich wrote: Hi mate ,
I had a similar experience driving along the m62 last yr. I tried ages to sort it changed wheels tyres. My motor has k.a.p springs ect so I contacted darren at k.a.p who knew straight away it was my pan rod bushes so i would start their as i,m sure their all pretty much the same.
I had this exact problem with my KAP panhard rod bushes. The metal collars inside the bushes were too long so the actual bush wasn't doing anything and causing undriveable death wobble. I cut the collars down, tightened everything up and this cured the problem.
- Dutchjimny
- Visitor
- Dutchjimny
- Visitor
- Seawolfvarna
- Visitor
I have the same problem. Presently, I am changing king pin bearings for both front wheel and also I am going to fit steering damper. I will let you know, what is the result. In my opinion it is not good idea to remove anti roll bar.
- Dutchjimny
- Visitor
- Collins
- Visitor
- Dutchjimny
- Visitor
