battery again
- SUGAR DELTA
- Visitor
- Smoggy
- Visitor
Reapers philosophy on this subject is sound.
- Thank you received: 153
SUGAR DELTA wrote:
supergaz wrote: Yup, just use a split charge system of lesser rating. 60Ah max.
60Ah split charging system,ok why is this please?
If I want to charge a 110Ah don't I need one that's rated for that ?
Cheers =)
This is because your jimny alternator only gives out 60Ah, you only need to trickle charge an auxilary battery.
I am a qualified electrical and electronic engineer and fully agree with Reaper.
- jimny5
- Visitor
Go with reapers advise, its nice and simple could even fit some gauges to double check readings.
- Johnniehec
- Thank you received: 56
SUGAR DELTA wrote: I was looking at this,would it be overkill?
This is not an automatic split charge system it's only a manual relay and a very expensive one at that, you can get the same relay here www.vehicle-wiring-products.eu/VWP-onlin...lays/relays.php#high
for £16 which means you're paying £54 for a couple of fuse holders, a bit of wire and a few cable ties.
I think you're after one of these, can someone confirm it's "big" enough?
John.
- SUGAR DELTA
- Visitor
John.
Cheers bud,I aint bought anything yet .
I echo can anyone tell me if 30amp is big enough to charge a 110ah leasure battery from the alternator?
The two batteries are not connected but have a split charging system.
One of the batteries is the main battery, used to start the engine and the second battery is for all other consumers.
This way even if you run out of battery you will be able to start.
- SUGAR DELTA
- Visitor
www.x-eng.co.uk/X-Charge.asp
- Jande
- Visitor
- Smoggy
- Visitor
- Jande
- Visitor
