battery again
  • SUGAR DELTA
  • Visitor
  • Visitor
22 Jan 2012 21:31 #31610 by SUGAR DELTA
battery again was created by SUGAR DELTA
I think i'm gonna get a split charge system and put a 110Ah leasure battery in the boot.
Question,would the standard alternator be good enough for this task ?
Cheers folks :)
  • supergaz
  • Visitor
  • Visitor
22 Jan 2012 21:38 #31614 by supergaz
Replied by supergaz on topic Re: battery again
Yup, just use a split charge system of lesser rating. 60Ah max.
  • TomDK
  • Visitor
  • Visitor
23 Jan 2012 09:36 #31625 by TomDK
Replied by TomDK on topic Re: battery again
SUGAR DELTA wrote: I think i'm gonna get a split charge system and put a 110Ah leasure battery in the boot.
Cheers folks :)
What's the reason you want a split charge system ?
If it's just for winching there's no real reason for it. Just parallel connect the batteries.
  • 247sniper
  • Visitor
  • Visitor
23 Jan 2012 11:14 #31630 by 247sniper
Replied by 247sniper on topic Re: battery again
Connect the batteries in SERIES.
Steve.
  • reaper
  • Visitor
  • Visitor
23 Jan 2012 11:41 #31631 by reaper
Replied by reaper on topic Re: battery again
dont direct connect batteries all this does is strain the alternator . split charger is the way to and for about a fiver will save you an expensive alternator
  • TomDK
  • Visitor
  • Visitor
23 Jan 2012 12:13 #31633 by TomDK
247sniper wrote: Connect the batteries in SERIES.
Steve.
And go for 24V ?
All the challengetrucks I've seen have no need for fancy split charger. Two batteries in parallel connection works fine.
  • 247sniper
  • Visitor
  • Visitor
23 Jan 2012 12:49 #31634 by 247sniper
Can you explain how two batteries can be wired in parallel ??
Steve .
  • reaper
  • Visitor
  • Visitor
23 Jan 2012 13:00 #31636 by reaper
2 in series =24v will blow car elecrics
2 in parralel = 2 x ah that will strain and posibly blow the alternator
ad to that the need for large cable running to the boot and its all a bit point less
get a cheep spliy charger it uses nice small cable that is eazily run . and it auto detects wbdn main batter if full and switches charge to secondary , no chancs of ever running main battery flat
  • TomDK
  • Visitor
  • Visitor
23 Jan 2012 13:13 #31637 by TomDK
247sniper wrote: Can you explain how two batteries can be wired in parallel ??
Steve .
It's not that hard.
+ > + (positive to positive)
- > - (Negative to negative)
  • reaper
  • Visitor
  • Visitor
23 Jan 2012 15:07 #31644 by reaper
the problem you have if not using a split charger is your 60A altanator trying to charge a 110A+60A battery
170A is to much for it
add to that the stronger of the 2 batteries will always try to back feed so it will not get to its full capacity and may even damage the smaller one by overcharging it
  • SUGAR DELTA
  • Visitor
  • Visitor
23 Jan 2012 18:37 #31663 by SUGAR DELTA
Replied by SUGAR DELTA on topic Re: battery again
supergaz wrote: Yup, just use a split charge system of lesser rating. 60Ah max.
60Ah split charging system,ok why is this please?
If I want to charge a 110Ah don't I need one that's rated for that ?
Cheers =)
  • SUGAR DELTA
  • Visitor
  • Visitor
23 Jan 2012 18:39 - 23 Jan 2012 18:43 #31664 by SUGAR DELTA
Cheers folks :)
The reason is I use amateur radio equipment and quite a powerful linear amp.
The radio draws around 10 amps and the linear around 45 ish..
Last edit: 23 Jan 2012 18:43 by SUGAR DELTA.
Time to create page: 0.158 seconds
