Tow Bar
- Carrow
- Visitor
- the tow bar seems to be around 10-15mm off centre to the left, does this cause any problems.
- the electrics look as though they could get knocked when off-road.
- does anyone have problems with some trailers being unlevel.
- the holes in the chassis seem to be 14mm yet bolts are only 12mm some other tow-bars are worse, having only 10mm bolts.
- Az1987
- Visitor
The electrics have been nailed offroad, i forgot 1st time out and bent the plate right up. I've bent it back but eventually i'm going to sink it flush into the bumper. Someone on here has done this already. I also broke the cover off so it often fills with mud, i tried covering it up but it still filled up with water. Before i go out now i spray it with plenty of wd40 and give it a good clean after and spray again.
The witter detachables are something like 3 times the price iirc.
- Az1987
- Visitor
- Carrow
- Visitor
- X-Eng Simon
- Visitor
Si
- adamatdraycott
- Visitor
I have a witter detachable, looks great and works great, but i too have bent the lecy braket more than once. I'll get round to having a heavy duty stainless one made at some point!
Mud doesn't seem to be an issue in the removable mechanism, dust and water is though.
- ZookFastback
- Visitor
The manual that came with my Jimny says towing capacities are 550kg unbraked, 1,100kg braked.
I use a Tekonsha electric brake controller and fitted electric operated disk brakes to my 690kg "Cabana" caravan and electric operated drum bakes to my small yacht trailer.
- ZookFastback
- Visitor
Quote
"Your SUZUKI was originally designed to be capable of towing a trailer which does not exceed the following towing capacity:
Towing Capacity
(Trailer, Cargo & Tow bar)
Braked trailer: 450 kg ( 1000 lb)
Unbraked trailer: 350 kg ( 770 lbs)
However, some countries have regulations which specifically allow trailer weights greater than the capacities shown above; vehicles sold in these countries have towing capacities which match the maximum trailer weight permitted."
Unquote
This is the sticker on drivers' door edge, showing the max in kgs, 1100 and downforce max of 75.
Australian Design Regulations waffle on a lot but basically say that a vehicle may tow up to it's own weight braked. and 30% unbraked.
What they allow in the UK is any bodies guess
- Thank you received: 34
So unless I reverse into deep water, there is no way its going to get mudded up.
I use a 1 meter coiled extension cable to connect to a trailer
Former owner of Little "Ooky", who has now started a new life in Shetland
- Adamski
- Visitor
mcjimny wrote: 1300kg braked and a measly 350kg i've always seen but even a quick google shows varying figures.
This is what it says on parkers.com but it is wrong
The Jimny tow's:
450kg braked
350kg unbraked
I regularly tow something 320kg and it copes pretty well but I wouldn't like to tow something 450kg long distances. Anything over 450kg would technically be illegal and I dont know what the punishment would be. I suppose if you were a chav you would get a slap on the wrist but an upstanding citizen would probably get 12 points and a £20k fine
