no drive from front axle
- darthloachie
- Visitor
as it says - currently have no drive from the front axle
both half shafts and CVs have been taken out and checked and are ok
both aisin hubs have been checked - wheels spin silently when free but can hear movement when locked
however only turning the nearside turns the prop shaft
I am guessing it is something in the front diff?
only problem is it has an ARB air locker fitted
is it going to be a suzuki bit or ARB bit thats broke?
guessing it may be a planetary gear thats buggered?
if I lock the diff with the locker then still only the nearside turns when you turn the prop
Any ideas are welcome
thanks in advance
depressed of Stone
- unsure
- Visitor
- darthloachie
- Visitor
- unsure
- Visitor
if you stop the NS from being able to turn and you turn the prop the OS should turn if the shaft and cv are good.
not sure if i make sense here....
i have had loads of diff and shaft and cv issues in he past....i own a landy...lol
- Johnniehec
- Thank you received: 56
unsure wrote: no but when it is not locked turning each wheel in tudn wont always make the prop spin. are you sure that both cv's and chafts are ok?
Sorry "unsure" but I'd disagree. Both front wheels off the ground with the hubs locked rotating either front wheel by hand would result in either the prop turning or the other wheel turning in the oposite direction, whichever is least resistance (with a standard diff or a locker unlocked). With the locker locked turning one wheel by hand would result in the other turning in the same direction AND the prop turning.
From how you have described it darthloachie it looks like one side of the diff but I'm not sure if that's possible have a look at this,
Are you definitely definitely sure it's not a half shaft?
- darthloachie
- Visitor
Had both half shafts out and they are fine - so are the CVs
when we broke it we also broke the rear prop so drove home with the arb locked and got drive only from the nearside front I think -it pulled to the left under power
- unsure
- Visitor
If you read it again, prop wont always turn.......ie damaged cv or shaft or hub
- Thank you received: 584
- darthloachie
- Visitor
I am going round tomorrow morning to collect the diff and will need to find another diff to get the arb fitted into and a specialist to do it to set the backlash etc as it is beyond our capabilities
will post pics tomorrow
so is there any particular diff I need or are they all the same?
the jimny is a 2000 hardtop with the 13gbb engine on a V
I am also looking for a specialist to fit the ARB in near or in North Staffs
any advice?
- darthloachie
- Visitor
mlines wrote: Just send the ARB to me, I will relieve you of the stress and strain its causing you and quietly dispose of it for you, you need never worry about it again
thanks for the offer but it wasn't the sort of advice I was looking for!!
- darthloachie
- Visitor
