BigJimnyMeet 2024
× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Rocklobster Question
16 Jun 2011 15:59 #17881 by ooky_123
Well after spending most of the afternoon under the car, attempting to fit the Rocklobster, I managed to get the car running in front wheel drive, and took it to my local garage to help me drill the rear diff flange.
Here is a photo of the finished article
I do have one problem though, I havnt bent the gear stick yet, so the transfer box is currently stuck in 4 Hi. I assume I need to get it bent back to allow me to select 2Hi.
Also, can someone give me a photo of the gear pattern .. Is it the same as the Jimny ?
2Hi --- 4Hi (push down) -- 4Lo ??
Former owner of Little "Ooky", who has now started a new life in Shetland
16 Jun 2011 16:05 - 16 Jun 2011 16:13 #17887 by MigCooper
Replied by MigCooper on topic Re: Rocklobster Question
Hi
On the lobster the patter is as follows:
.............4L
2H....... N
4H
Dont mind the dots, forum removes the spaces so had to redo this ..... :ohmy:
3" Spring Lift + 1" Spacers / ES300 Shockers / TJM Snorkel / Extended Brake Lines / Castor Correction Bushes / Adjustable Panhard Rods / 30" Kaiman / 4.16 Redacted lobster / No Anti Roll Bar / Rock Sliders (Home made) / Diff Guards from ORA / 32mm Spacers /...
Last edit: 16 Jun 2011 16:13 by MigCooper.
16 Jun 2011 16:07 #17889 by ooky_123
Replied by ooky_123 on topic Re: Rocklobster Question
Also just noticed after a quick test drive that the gear stick seems to be touching either a UJ or a balance weight if you push down on it when changing gear ... a common problem #?? maybe need to go slightly higher on the lift ... ?
16 Jun 2011 16:08 #17891 by mlines
Replied by mlines on topic Re: Rocklobster Question
The change pattern on a Rock Lobster is in the shape of a backwards J
2H at the top
4H at the bottom
4L at the tip of the "hook"
16 Jun 2011 16:09 #17892 by ooky_123
Ahh that explains it then ... even with a 1" cut in the floot, i cannot select the 2Hi (Neutral) position ... ok, so bending is essential ...
MigCooper wrote: Hi
4L
2H N
4H
16 Jun 2011 16:10 #17893 by MigCooper
.............4L
2H....... N
4H
16 Jun 2011 16:11 #17894 by mlines
ooky_123 wrote: Also just noticed after a quick test drive that the gear stick seems to be touching either a UJ or a balance weight if you push down on it when changing gear ... a common problem #?? maybe need to go slightly higher on the lift ... ?
You get a "ting", "ting", "ting" noise. I had this, its the bolts are too long on one of the flanges if I remember correctly, they foul something.
It gets worse when you "load" the transmission (i.e. steep hill start)
16 Jun 2011 16:21 #17896 by MigCooper
I got the same cutting the bolts solved it as well
16 Jun 2011 16:35 #17897 by andyw
Replied by andyw on topic Re: Rocklobster Question
I'm sure It's
....................4 L
....................l
...................__ N
2H...............l
l...................l
l_________l 4H
you get the idea lol..................................get the oxy on it to get a good kink in the stick, really red and it will bend where you want it and not like a bananaB) .......or some people grind it nearly through and then weld it.
Andy
16 Jun 2011 16:57 #17900 by mlines
Ok - I had it the wrong way around.
Attachment sized_IMGP7523.JPG not found
16 Jun 2011 18:27 #17906 by ooky_123
Thankyou Martin / everyone. I think a visit to my local garage to get the gear stick bent and I guess im off to look for a genuine gear knob
23 Jun 2011 21:55 - 23 Jun 2011 21:56 #18197 by ooky_123
Sorry .. Both wrong !!! .. I was looking at the problem today, and it appears to be speed specific .. so, with the lobster box in neutral, and the jimny in Gear, i started to investigate.. The problem appears to be a balancing weight on the mini prop is fouling the bottom of the gearstick assembly. It is more prominent when the gear selector is in the rear position (2nd, 4th, Reverse).
Closer inspection, the underside of the gearstick is on rubber bushes, and these have quite a lot of play. Now .. ignore or try and fix the problem ???...
Last edit: 23 Jun 2011 21:56 by ooky_123.
Time to create page: 0.173 seconds
Powered by Kunena Forum
