Fitting a plastic bullbar
- goatboy
- Visitor
Has anybody fitted (or even removed) a plastic suzuki bull bar?
I got one from a scrapyard (delivered to me I doidn't take it off myself) and I can't work out for the life of me how its meant to be installed. It came with 2 L shaped brackets (see pic) that don't seem to tie up with anything...
Also I'm not sure if the existing centre section (black bit just below the grill in the attached picture) of the front bumper is meant to be removed or if it fits over the top of it....
Can anyone help?
Thanks!
- biggaz
- Visitor
- goatboy
- Visitor
- trextr7monkey
- Visitor
- goatboy
- Visitor
I'll check out the site. Thanks.
- George 147
- Visitor
- goatboy
- Visitor
George 147 wrote: Black plastic piece stays in place. L brackets fit to chassis and protrudes through existing bumper and new bar attaches to the other end. You should have had 3x plastic spacer tubes with it two longer ones and a shorter one. These go in between the new bull bar and the existing bodywork up in under the front of the vehicle three holes at the rear of the bull bar. the short tube goes in the middle. Hope this helps.
Thanks George!
So it sounds like I have to cut the existing bumper then to get the L brackets on? Do they go forward from the chassis through the front of the bumper? (no obvious holes on anything on the bull bar which is confusing me).
I didn't get any spacers but thats easy to fix...
- George 147
- Visitor
- goatboy
- Visitor
Thanks!
- Skinhead
- Visitor
- goatboy
- Visitor
- blakey2000
- Visitor
but thoes brackets go onto the chassis and on to the black part of the bumper. should be 3 holes in the middle of the black part one center and 2 either side of it, at like 10-30cm away either side
bolts onto the chassis on the flat protuding part of the bumper.
