Rear leaning suspension
26 Feb 2011 18:25 #12212
by wildfire
Rear leaning suspension was created by wildfire
Ok, noticed to day that the rear nearside suspension has droped about 1.5cm, compared to the off side. It is most noticeable when going up hill as you can hear the wheel rub in. Oh this after Tong, which i did the blue with a couple of reds, there was a bang at one point, although i think this may be bottoming out.
Going to have a look tommrow, and see if there is any thing amiss. Any one got any hints whats to look for?
- Thank you received: 610
26 Feb 2011 19:07 #12213
by facade
Replied by facade on topic Re: Rear leaning suspension
A broken spring sounds most likely.
You could have bent the shock absorber enough to seize the suspension on that side, but I'd look at the spring first.
- gazert
- Visitor
26 Feb 2011 19:44 #12223
by gazert
Replied by gazert on topic Re: Rear leaning suspension
Sounds like you snapped the tail off your spring!
Quite commen on cold sprung steel.
06 Mar 2011 23:27 #12734
by wildfire
Replied by wildfire on topic Re: Rear leaning suspension
Well, had the car up on the stands and had the springs off, all present apart from some missing plastic coating. It seams that the "lean" was down to the placement of the emergency bag (basic tool kit, first aid etc) and the hi-lift jack and associated kit. Having removed all this it is back to normal, but when i have a passenger in the Jim-Jam there is still rubbing occurring when going up hill. Is this due to the spring getting old or should i be looking at some thing else?
- biggaz
- Visitor
07 Mar 2011 07:50 #12742
by biggaz
Replied by biggaz on topic Re: Rear leaning suspension
wa there any leakage from the shock on that side? maybe the shock has had it?
- panosd
- Visitor
07 Mar 2011 17:07 #12773
by panosd
Replied by panosd on topic Re: Rear leaning suspension
I also have this problem for a week now. After a hard 4x4 day. when i got back home and park,
i noticed that at the right back side the car is 1,5cm shorter.
I took a look under to the bolts etc and all looked ok.
Know every time i get a co-driver and passenger at back seats the car bends at rear right about 1,5cm.
When i am alone its ok.
What the is going on?
08 Mar 2011 14:11 #12830
by wildfire
Not that I could see, Also tried the push down and bounce back test which was no difference to the other side.
- biggaz
- Visitor
08 Mar 2011 14:47 #12831
by biggaz
theres only one solution....
3" lift!
3" lift!
- LEE65
- Visitor
08 Mar 2011 15:52 #12832
by LEE65
Replied by LEE65 on topic Re: Rear leaning suspension
without much info....has the Jimny got a lift at all.????
just a shot in the dark....maybe the suspension has seen better days if its std ?
more info would help try and determine the issues......
Lee
Lee
08 Mar 2011 19:15 #12841
by wildfire
Nope just standard suspension, just shy of 60K miles (2001). Starting to think its just getting old. Been looking at the 2 inch lift kits as alternative replacing as standards are about the same price, and the wife has agreed that it makes sense! This will have to go on the back burner as moneys tight with moving house and a baby coming up, I just want the car to be safe.
Perhaps I should mention these hills are steep, the Jimny needs to 3rd / 4th at high revs to get up them at a reasonable speeds.
- LEE65
- Visitor
08 Mar 2011 19:31 #12847
by LEE65
im sure with everyone fitting lifts some one will have some std ones going cheap
just make sure they are off a low mileage one...
i think thats prob it if its had a little abuse off road its prob just seem them off a little
early not sure they are designed for tong events lol
Lee
Lee
- biggaz
- Visitor
08 Mar 2011 19:34 #12850
by biggaz
yeh, gotta be tired then kicked in the teeth at TONG.
Mite aswell get a small lift if your replacing with new stuff!
Time to create page: 0.156 seconds
