Oil filter removal.
- Roger Fairclough
Topic Author
- Thank you received: 210
15 Feb 2024 22:13 #254358
by Roger Fairclough
Oil filter removal. was created by Roger Fairclough
Just completed a 12 month service on my Gen.4 and had a problem removing the oil filter. Due to the close proximity of the filter to the sump, my chain wrench could only grip the filter at the end furthest from the seal. The filter was unusually tight - probably no lube on the seal - and although I got it off, the end was mangled. I have been looking at alternatives and Toolstation sell a strap wrench which will get into the restricted space without any problems.
My question is, has anyone got a suggestion based on experience?
Cheers
Roger
Cheers
Roger
- Thank you received: 1795
16 Feb 2024 05:55 #254362
Replied by Lambert on topic Oil filter removal.
On the m series the filter is obscured by the exhaust manifold so I bought a set of cup wrenches that engage with the flats on the filter and are driven by a half inch square. They are great.
16 Feb 2024 06:01 #254363
- rogerzilla
- Visitor
16 Feb 2024 06:34 - 16 Feb 2024 06:53 #254364
by rogerzilla
Replied by rogerzilla on topic Oil filter removal.
I use the 3-claw self-tightening type (Sykes-Pickavant).
Last edit: 16 Feb 2024 06:53 by rogerzilla.
- Thank you received: 401
16 Feb 2024 10:57 - 16 Feb 2024 10:59 #254371
Replied by yakuza on topic Oil filter removal.
productimages.biltema.com/v1/image/image...ame/19-1530_xl_1.jpg
This kind has never let me down but havent been in the gen4 situation. The handle can be at an angle.
Last edit: 16 Feb 2024 10:59 by yakuza.
16 Feb 2024 17:39 #254382
by Busta
Replied by Busta on topic Oil filter removal.
- grumyoldjoe
- Elite Member
- Thank you received: 20
16 Feb 2024 20:11 #254384
by grumyoldjoe
Wine improves with age.
Replied by grumyoldjoe on topic Oil filter removal.
One of these served me well in the past
media.screwfix.com/is/image/ae235/302RH_...d=257&hei=257&dpr=on
- Doctorchris
- Senior Member
17 Feb 2024 06:20 #254391
by Doctorchris
Replied by Doctorchris on topic Oil filter removal.
I use a strap wrench that fits onto a socket wrench. I use it because that's what I have had in my toolkit for ages. It works but it is rather awkward, especially taking up the tension in the strap. If I was buying a new device specifically for the Gen4 Jimny I would choose something else.
- Roger Fairclough
Topic Author
17 Feb 2024 09:24 #254394
by Roger Fairclough
Replied by Roger Fairclough on topic Oil filter removal.
Many thanks for all your responses. The Gen.4 oil filter is approx. 63mm in diameter which is right at the bottom end of the usual " fits filters between 62-120mm in diameter" so yes, there is a problem of excess slack in chain or strap. I made my chain wrench to suit the very large filter on my LC and so had the fiddly problem of getting it onto the Jimny's filter and then holding it into position whilst lying on my back. Not easy! I intend to visit Toolstation and look at a Draper fabric wrench and consider if shortening the strap material would make it easier to use.
Roger
Roger
- Roger Fairclough
Topic Author
19 Feb 2024 17:24 #254447
by Roger Fairclough
It's warmer and drier so I got underneath to measure the gap between filter and sump. Answer is approx. 10 mm ( gap actually tapers but 10 mm is close enough). I measured my chain wrench ( std. bike chain ) and decided a bit of grinding would suffice and bingo, it fits nicely, so problem solved ( hopefully, it will be 12 months before I try it out ).
Roger
Roger
- rogerzilla
- Visitor
19 Feb 2024 17:41 #254448
by rogerzilla
You could use the time-honoured, if messy, method of banging a big screwdriver right through it.
19 Feb 2024 20:11 #254452
by Busta
Banging a screwdriver through is the worst thing you can do! If the filter is tight it just peels the filter open like a can opener, then you are left with a mangled, jagged, dripping mess to remove.
If you're smart enough to oil the o-ring and not over-tighten the new filter it should only be hand tight when the time comes to change it. But most people can't resist over tightening them.
Time to create page: 0.170 seconds
