Cylinder 2 misfire cold start
20 Nov 2023 19:34 #252245
by Dimitris
Cylinder 2 misfire cold start was created by Dimitris
Hello
I got a Jimny 2005 and I have an issue. When the weather is cold the car in the morning starts easily but its not sounds well. If i press the gas pedal between 1500 and 2000 rpm the engine light is blinking. If the car get warm then it works just fine. The scanner shows the error "misfire cylinder 2". Does anyone experienced something similar?
I must say that I have already replace spark plugs and coils.
- Thank you received: 475
20 Nov 2023 23:47 #252252
Replied by DrRobin on topic Cylinder 2 misfire cold start
What did the old plugs look like? Was the plug from cylinder 2 a different colour to the others?
21 Nov 2023 12:57 #252265
by Dimitris
Replied by Dimitris on topic Cylinder 2 misfire cold start
I am not sure about the colour. I thought about the injector on cylinder 2 but it works good when it's warm. What sensor finds the misfire on cylinder?
21 Nov 2023 13:24 #252267
Misfire is usually detected by the crank position sensor, it expects to see the 'kick' in rotational speed for each firing and if it doesn't it knows it was a misfire. It then uses the crank position vs the spark plug firing to know which cylinder didn't fire.
The reason for asking about colour was looking for cylinder head gasket, rings, or a sticking valve, but if it runs fine when warm you might not notice any difference in plug colour.
It could be a faulty injector, that works well enough when warm but is sluggish when cold.
I take it you battery is well charged?
Robin
Robin
- rogerzilla
- Visitor
21 Nov 2023 13:52 #252271
by rogerzilla
Replied by rogerzilla on topic Cylinder 2 misfire cold start
The crank position sensors are a known point of failure, snd fairly cheap and easy to replace.
21 Nov 2023 14:33 #252274
by Dimitris
The battery is new. I will start withe the injector and then the crank position sensors
Thanks a lot
Thanks a lot
21 Nov 2023 19:44 #252279
I doubt it’s the crank position sensor, a faulty one wouldn’t give a misfire on cylinder 2 only, it’s would be on different cylinders.
If it is only on cylinder 2 then it is going to be something specific to cylinder 2. You have changed plugs and coils, so an injector is the next thing, unless there is something more seriously wrong with cylinder 2.
The following user(s) said Thank You: Dimitris
- Thank you received: 16
21 Nov 2023 20:22 #252281
by Phaeton
Replied by Phaeton on topic Cylinder 2 misfire cold start
Swap the plug, injector & coilpack from No 2 with another cylinder & see if fault follows, if it does you're down to the 3 items, if it doesn't it could well be mechanical.
- Thank you received: 610
21 Nov 2023 21:02 #252282
by facade
Replied by facade on topic Cylinder 2 misfire cold start
Do a compression test when cold and see if cylinder #2 is lower than the others.
A burnt exhaust valve will cause enough compression loss for a missfire at idle, but seem to get better when the engine is running at speed.
28 Oct 2024 19:00 - 28 Oct 2024 19:26 #258080
by Dimitris
Hello again. Now that the temperature in the morning is near water freezing point the problem appears again. Compression test is ok. New spark plugs and coils. Swap the injectors with no difference. Compression is ok. When the engine gets hot , it runs just fine. Any idea by someone? Thanks
Last edit: 28 Oct 2024 19:26 by Dimitris.
- Thank you received: 1802
29 Oct 2024 04:20 #258084
Replied by Lambert on topic Cylinder 2 misfire cold start
Are the spark plugs correctly torqued and the plug leads correctly and firmly seated on the plugs
29 Oct 2024 04:37 #258086
by Dimitris
Yes. I check it many many times
Time to create page: 0.156 seconds
