31” tyres, 2” lift, standard bumpers?
- martinjsmith6
20 Apr 2023 19:34 #248731
by martinjsmith6
31” tyres, 2” lift, standard bumpers? was created by martinjsmith6
Hi all,
I’m relatively new here so hello!
I have stock Jimny currently running standard suspension with 215/75/15 Toyo AT’s. These are great tyres but I’d quite like a little more ground clearance and more mud plugging capabilities. I don’t want anything more than a 2” lift as I do daily the car for around 10 miles and I cannot be bothered faffing around changing brake hoses and stuff. I don’t mind doing a little bumper trimming within reason. What do you think is the max size tyres I can put on? I’m currently looking at either 235/75/15 which would give 1.2” lift which I’m not sure is quite enough or 31/10.5/15 which would give 3.3” lift.
- Thank you received: 1801
21 Apr 2023 03:26 #248732
Replied by Lambert on topic 31” tyres, 2” lift, standard bumpers?
Anything bigger than the 215 you have now is going to need a regear of some description as you will quickly burn up either the clutch or the transmission fluid. Not saying it can't be done just that it's not as simple as fitting the tyres under the car.
- Thank you received: 415
21 Apr 2023 13:12 #248737
Replied by yakuza on topic 31” tyres, 2” lift, standard bumpers?
My clutch is smelly also with the 235 and low gears. It holds but will be changed. And 235 without more engine or gearing will make a dull car. 31 would need major cutting of the fenders and bumper to clear.
All this based on my own experience.
21 Apr 2023 13:31 #248738
by saxj
On a gen 3, 235's don't fit with a 2" lift. You need to some cutting.
On a gen 4, 235's just fit with a 2" lift with a little trimming of the front bumper.
Replied by saxj on topic 31” tyres, 2” lift, standard bumpers?
You don't say which model Jimny you have.Hi all,
21 Apr 2023 16:42 - 21 Apr 2023 16:46 #248743
If you accept minor rubbing on full flex 235 is ok on stock wheels. No cutting. Yes the stock wheels are too narrow so in some peoples book it is not ok. But for me it works fine.
Edit: and no mud flaps.
Last edit: 21 Apr 2023 16:46 by yakuza.
- martinjsmith6
22 Apr 2023 20:45 - 22 Apr 2023 20:46 #248767
by martinjsmith6
Replied by martinjsmith6 on topic 31” tyres, 2” lift, standard bumpers?
Sorry forgot to add that bit! It’s a Gen 3 Automatic.
Last edit: 22 Apr 2023 20:46 by martinjsmith6.
23 Apr 2023 04:57 #248769
Then I stand by my earlier comment that you will cook the transmission fluid. The bigger tyres will cause the torque converter to be in a state of slip for extended periods which will over heat and denature the fluid. Adding additional coolers will only mask the problem, a new set of transfer gears over comes it. There's also the issue of stress as applied to both the internal parts of the axles and also the outer tubes themselves. You can expect to be changing wheel bearings and kingpin bearings as a regular service item and while the automatic is gentler on the CV joints it's likely they will have a much reduced service life too, now you can get bigger stronger CV joints but they are multiple times the cost of stock ones so it becomes a question of value. Then there is the issue of the axle tube bending or cracking the welds which leads to trussing the axles. These are all problems that go away with the application of money of course. Also you can expect to need the angle grinder to interact with the front chassis body mount to retain some degree of steering especially when the wheel is compressed fully, again all perfectly doable but not necessarily a weekends work. All that said though a Jimny on 31s is quite a capable thing when done properly. Especially if you add axle lockers.
23 Apr 2023 10:22 #248772
Having done most of the mods for large tires and only driving on 235 i am with Lambert here. Have no experience with auto though but still mostly the same.
With my current setup with low gears, more engine ++ I would still be in doubt to go to 31.
- martinjsmith6
23 Apr 2023 15:07 - 23 Apr 2023 15:10 #248778
by martinjsmith6
Ok so sticking with the 215’s I have now, is it worth doing a 2” lift?Then I stand by my earlier comment that you will cook the transmission fluid. The bigger tyres will cause the torque converter to be in a state of slip for extended periods which will over heat and denature the fluid. Adding additional coolers will only mask the problem, a new set of transfer gears over comes it. There's also the issue of stress as applied to both the internal parts of the axles and also the outer tubes themselves. You can expect to be changing wheel bearings and kingpin bearings as a regular service item and while the automatic is gentler on the CV joints it's likely they will have a much reduced service life too, now you can get bigger stronger CV joints but they are multiple times the cost of stock ones so it becomes a question of value. Then there is the issue of the axle tube bending or cracking the welds which leads to trussing the axles. These are all problems that go away with the application of money of course. Also you can expect to need the angle grinder to interact with the front chassis body mount to retain some degree of steering especially when the wheel is compressed fully, again all perfectly doable but not necessarily a weekends work. All that said though a Jimny on 31s is quite a capable thing when done properly. Especially if you add axle lockers.
Last edit: 23 Apr 2023 15:10 by martinjsmith6.
23 Apr 2023 16:19 #248793
It will improve the clearance angles for climbing about on stuff so a lift isn't without merit, it will also be replacing worn standard suspension with new so the ride quality will improve assuming you get a good reputable brand of lift. But unfortunately it will not alter the clearance under the diffs so ruts are still going to need thought. Many people have but but I'm not one of them.
- martinjsmith6
23 Apr 2023 17:17 - 23 Apr 2023 17:17 #248798
by martinjsmith6
I was thinking exactly that on the worn standard suspension. What brands do you recommend I go for? I’ve been looking at the black raptor kits on Jimny bits, are they any good?It will improve the clearance angles for climbing about on stuff so a lift isn't without merit, it will also be replacing worn standard suspension with new so the ride quality will improve assuming you get a good reputable brand of lift. But unfortunately it will not alter the clearance under the diffs so ruts are still going to need thought. Many people have but but I'm not one of them.
Last edit: 23 Apr 2023 17:17 by martinjsmith6.
- Thank you received: 662
23 Apr 2023 17:37 #248800
Replied by jackonlyjack on topic 31” tyres, 2” lift, standard bumpers?
Raptor kit will be fine
If you want it more capable off road remove anti rollbar or fit a disconnect kit
This will allow full articulation on front axle
But you will need extended brake lines if you go this route
Time to create page: 0.209 seconds
