Re:Re:Re:Jimny pulling to right
I did adjust it too much at first and that did seem to make it pull to the right, but backed off the drag link a bit and the steering wheel is almost perfectly straight and no pulling. I haven't bothered trying to get it absolutely spot on as it would be such a small adjustment I would probably end up going too far again.
@lambert the power steering is electric .
- Thank you received: 1999
My simple thought process on it.
- lookonimages
- Thank you received: 72
Lambert, yes. I will take it back to the steering specilist in cape town, but that will be only next week some time when I go to Cape Town again.Lambert wrote: Thanks mate. So it being electric there more than a chance that it knows where centre should be and it's attempting to maintain that position. It will probably have some feedback sensors which may be confused and need recalibration or something like that. Either way it's sounding like a controller issue rather than an alignment issue. Might be worth having a comprehensive code reading session see if anything thinks it's unhappy.
When they had it hooked up last week to their computor it showed the parameters is in line with suzuki (but that is parameters for standard Jimny) he showed the data reader screen data to me, but I guess it is correct set to "standard" position. Maybe they need to adjust the "standard" parameters to now correct for the lift and thus correct the steering wheel.
Their is something that move the steering wheel to a specific position the moment the wheels starting to rotate.
So on the steering data reader and electronic settings, i will only be able to give feedback next week then. But there sure is some setting for that "rest" position, I am pretty sure now.
- lookonimages
So it seems the steering angle sensor position can be set / recalibrate for electric steering assist systems - if you have to tools.
Nit much on Jimny's but lots on other cars that have had this technology for much longer.
The guy in Capetown have simmilar diagnostics tool (tablet type) as in video below so maybe we can be lucky next week.
Google "steering angle sensor position"
