Mud Tyres
- GGB
- Visitor
Has anyone any experience of these tyres, or know any better mud tyres suitable for the Jimny??
Where can I get some steel 6" width 16" dieameter wheels to suit Jimny?
Thanks
GGB
- Thank you received: 1761
- GGB
- Visitor
Cheers.
- Thank you received: 552
I personally think you are on the verge of spending £££ on new tyres with only marginal improvement if any. The tyes you have should be good enough if they have enough tread depth, so as suggested already try altering the tyre pressure.
Having said that some "claggy" mud is just impossible, it bungs the tread instantly and reduces traction to ice levels.
But if you want new tyres why not, best place to ask
Hope you find what you need.
Mike
- GGB
- Visitor
We don't really use the car on the road, other than fill up with fuel.
The tyres I am looking at are tractor tread, see photo. They will go on a 16" wheel and are 686mm diameter, which is fine.
Thanks all.
- Thank you received: 653
You can import from Japan if you have silly amounts of money
- Groundworker
- Visitor
My only real experience with the Jimmy is trialling so we obviously get directed towards the worst ground conditions, we often cross deep ruts, or try to steer out of them, it's hard to imagine conditions that would defeat the Jimmy unless you have ruts which leave you high centred.
In my experience the one thing the Jimmy doesn't like is steep climbs with an axle twister involved, here I think the light weight is a disadvantage. The Jimmy's in our club very rarely need recovery.
- Thank you received: 168
GGB wrote: I have a set of 205/70 R15 INSA Turbo off road 4x4 tyres on our Jimny but they are no good in our muddy field. I am looking at getting a set of BKT Agrimax RT-765TL 200/70 R16 tyres and changing to 16" rims 6" width.
Thanks
GGB
GGB wrote: Thanks Scimike, I agree with your comments and might try reducing the tyre pressure more, thanks to Saxj for that suggestion as well. There is plenty of tread on the tyres as they are brand new, but we have been really unimpressed with them, the mud did fill up the treads and they were slicks, so totally useless.we have had to use the Disco, on all terrain tyres, to tow it out of the field.
I just want to check. The tyres you say you have are these?
If so, they are very aggressive mud tyres. You are unlikely to find much better.
A full on Ag tyre might offer a bit more traction, but it is likely to be marginal.
Can I ask, what type terrain/mud are you driving on? Are you in the UK, if so, what area?
You also mentioned about a Discovery on AT's rescuing the Jimny. I assume you meant to drove on the same ground with the Disco?
This would then lead me to also ask:
-Has your Jimny ever been any good off road or have you only just got it?
I ask this as maybe it isn't a tyre thing. Are you certain that 4wd was working? If the vehicle was in 2wd with open axle diffs, you would essentially have 1wd. Which on a slippery muddy hill would get you know where.
Pretty sure it is legal to run lower speed rated tyres. You'd just need to notify your insurance. e.g. Many modern SUV/4x4's have pretty high top speeds, but you can still legally fit and run Mud Terrains on them with lower speed ratings.Lambert wrote: Just looking at the bkt you mentioned above and the speed rating is limited to 25 mph which as I understand it is illegal for use on a vehicle that can exceed that speed. Plus it being an agricultural tyre is going to immediately be of interest to the constabulary if they see it on a car in the local petrol station.
For example, my 4.6 Range Rover is rated at 124mph top speed. I believe a set of BFG KM3 MTs are Q speed rated which is only 100mph.
