BigJimnyMeet 2024
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
King pin still leaking????
  • Olliecarr25
  • Visitor
  • Visitor
14 Jul 2020 20:57 #225102 by Olliecarr25
King pin still leaking???? was created by Olliecarr25
Hi there I have a 2002 Suzuki jimny and the other week I did the king pins and the little seal and I changed the diff oil it was fine at first but after a couple days driving and then being sat about for a few days one side has started to leak again any ideas? Thanks Ollie
14 Jul 2020 21:34 #225104 by Scimike
Replied by Scimike on topic King pin still leaking????
HI, t's very easy to damage the seal as you push the half shaft back, could be as simple as this.
  • Riccy
  • Riccy's Avatar
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
15 Jul 2020 16:22 #225128 by Riccy
Replied by Riccy on topic King pin still leaking????
or seal not seated properly, I've had that one before :huh:
16 Jul 2020 07:49 #225151 by Busta
Replied by Busta on topic King pin still leaking????
Have you over-filled the swivel with grease? It only needs a smear in the back of the CV joint.
  • Olliecarr25
  • Visitor
  • Visitor
16 Jul 2020 12:25 #225163 by Olliecarr25
Replied by Olliecarr25 on topic King pin still leaking????
Am I right in thinking it has to be the seal for the diff oil to be in there anyway?
  • Lambert's Avatar
  • Away
16 Jul 2020 12:28 #225165 by Lambert
Replied by Lambert on topic King pin still leaking????
Yes.
19 Jul 2020 18:42 #225335 by kirkynut
Replied by kirkynut on topic King pin still leaking????
Last year I replaced the oil seal and kingpin bearings on a family friend's Jimjam and it leaked a couple of months after. To get her through the MOT someone else drained the front diff at my advice and she was told not to select 4wd.
Today I replaced the kingpin bearings again, albeit they were likely ok and the seal but shimmed them with annealed copper washers. I've done this on mine with good results.
The seal was absolutely trashed but I know I put it in properly and square and I didn't damage it putting the shaft in. The wheel bearing seems tight and quiet too.
I'm at a loss as to why the seal lips were so flattened. I'm hoping it will be good for a few years now and with new oil in the diff it can be used in 4wd this winter if required.
Thankfully the 4wd system worked after I had it apart as you have to disturb several seals and pipes from the vacuum system. There were 2 audible clicks and the light was solid, not flashing.
  • shaggy
  • Visitor
  • Visitor
10 Sep 2020 11:29 #228034 by shaggy
Replied by shaggy on topic King pin still leaking????
I've recently done the kingpin bearings/ oil seal/shim/grease job on both sides of my 03 Jimny and passenger side is still leaking.From reading this, I guess I'll have to order a new halfshaft oil seal and be more careful re-installing the halfshaft.
How does too much grease in the swivel cause this issue? Does it cause grease to leak or diff oil as it smells like diff oil is leaking on mine.
It could also be that I haven't brought it to get it's tracking done and wheels balanced after the second kingpin was replaced and that a small wobble in the drive shaft might be compromising the seal.
Also is there a way to know how many shims to use?
10 Sep 2020 11:42 - 10 Sep 2020 11:48 #228035 by Scimike
Hi,
The grease will not cause the issue. You only need enough to coat the Kingpin bearings and inside CV joint, any more is just wasted and a gunky mess.
If it's leaking still it's likely to be diff oil getting past the seal. Damaged seal or grooved shaft (the bit the seal runs on) are possible causes.
You only need shims to achieve the correct swivel load, it's about 3kg (someone please confirm, I can't recall exactly) to get the swivel moving from side to side. It's possible you don't need any with new bearings, mine has none fitted.
Last edit: 10 Sep 2020 11:48 by Scimike.
10 Sep 2020 13:01 #228038 by HUN
Replied by HUN on topic King pin still leaking????
Scimike wrote: Hi,
Service bulletin says the maximum swivel load is 4.6kg (45Nm) or less.
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
10 Sep 2020 13:34 #228040 by mlines
Replied by mlines on topic King pin still leaking????
I have tried on many occasions to measure the starting load on the swivels when fitting with shims.
In the end I resorted to the "Goldilocks" process.
This involves simply swiveling it by my finger tips and seeing how it felt - Too Hard > less shims Too Soft > more shims Just Right = success.
Its hard to describe this but you can literally feel it in your fingers and sense that it is just right
  • mic888
  • Visitor
  • Visitor
10 Sep 2020 14:08 #228042 by mic888
Replied by mic888 on topic King pin still leaking????
Had a similar issue on my last jimny only way i could stop it from leaking was to fit a genuine suzuki seal and that was on the long shaft side.
Time to create page: 0.150 seconds
Powered by Kunena Forum
