None Charging Jimny
- Grasshopper
- Senior Member
- Thank you received: 5
Looking for some ideas on a none charging issue on a M13A engine.
In ignition position two the battery charge light is on, once the engine is running the light goes out and remains so.. .However the vehicle if left to normal on road running it will eventually flatten the battery. Using a multimeter a fully charged battery voltage is indicated, however this does not increase/change when RPM is increased ( I would be typically looking for 14.1 plus volts ).
I have fitted a new alternator and since the battery was eight years old I have also fitted a new battery, still no charging the battery remains at basic voltage I have obviously looked for bad connections etc but nothing visible.
Any ideas would be much appreciated
Dave
The only benefit of age is experience.
- Thank you received: 260
Just a quick one - a thought that is coming from personal and humiliating experience -. Is the alternator belt tight enough.Grasshopper wrote: Hi All
Dave
- Thank you received: 1763
It's been fettled just a tad.
- Grasshopper
- Senior Member
The one that has got me going a bit is Jazz's suggestion of "checking the fuse". I assume you mean the 80 amp fuse hidden away under the engine bay fuse box.which looks a less than easy to get at. Surely if that's blown there will be no electrical power throughout the vehicle.
That said I read on another forum somebody referred to the fact that if it had failed the alternator won't charge the battery but he does not say the whole system is dead. Suppose I will have to have a dig under that can of wiring/worms.
- Thank you received: 584
Grasshopper wrote: The one that has got me going a bit is Jazz's suggestion of "checking the fuse". I assume you mean the 80 amp fuse hidden away under the engine bay fuse box.which looks a less than easy to get at. Surely if that's blown there will be no electrical power throughout the vehicle.
You are correct, there shouldn't be, the feed to the vehicle spurs off on the alternator side of the fuse.
The B terminal of the alternator goes to that fuse via a white wire.
I'd check the voltage on the B terminal (the ring that takes the thick white wire) of the alternator is battery voltage when switched off, and around 14V when the engine is running. If the warning light comes on and goes off when it is running it ought to charge.
(The ancient electrical system on mine is a bit flaky, I have corroded connections somewhere as the voltage at the cigarette lighter goes up and down when I turn things on and off and the headlights are a bit dim, but there is a solid 14V at the battery when it is running- and the wheels still go round so it is fine.....)
- Grasshopper
- Senior Member
Will check voltages at alternator (bearing in mind I have fitted a new one) and that wiring diagram will be very helpful.
I won't mind but here in North Wales we have plenty of hills, its just starting to snow again and my favorite little 4 x 4 beast is not well. So I have to use my great lumbering old Volvo which is great on long haul stuff but like a beached whale in snow. LOL
If you attach a flying wire to that B terminal (Don't let it touch earth, or you will blow that 80A fuse!!) there should be close to zero volts between that B terminal and the battery positive with the engine running, I'm betting you have around 2 volts, the difference between the charging voltage 14.something and the battery 12.5 or so.
- Grasshopper
- Senior Member
Due to a serious family issue I am having to put resolving my sick Jimny problem to one side and use Agnetha ( named after the lass in Abba ) the big Volvo.
I will try all the suggestions and report progress ASAP, it accrued to me what about a failed earth strap from engine to main earth point on body/chassis, or does the alternator have its own earth line wire ? I am old enough to remember when vehicles had a proper chunky flexible strap from the engine to chassis..
- Grasshopper
- Senior Member
Had done all my own checks plus some good suggestions from the forum. So I went over it all again, voltage output from alternator, fuses, earths, connections and continuity etc. I was then considering was their some heavy draw that was only present when the key was in the run position and the alternator could not overcome it to restore battery level.
The first forum response I had was from helijohn were he suggested alternator drive belt tension, I had fitted a new belt within last twelve months ( just routine maintenance) and it was my first check point when this problem started , I had also changed alternators just in case there was an intermittent fault, always putting on a sensible belt tension, so surly this could not be the issue, besides the alternator was showing 14.4 volts when on test !
Really at a point of desperation I dragged off the new' sh drive belt and fitted a new one with the same level of tension, on start up immediately 14.3 volts at the battery ! .Inspecting the removed 'V' belt I found that it was stretchy, that certainly was not obvious when fitting it ( lord knows as a time served fitter I have fitted enough accessory drive belts ), I can only assume once the alternator load came on it reacted.
under loan.
So thanks very much to all who contributed particularly facade, jezz and helijohn
Lesson to be learn for me is go back to the obvious and don't be surprised by the unusual.
Dave
