transmission control module
- jaybe
- Visitor
07 Aug 2015 01:08 #149269
by jaybe
transmission control module was created by jaybe
hi, can anyone out there help, my Suzuki jimney badly needs a transmission control module, have been told by garage, that Suzuki no longer supply them, is this true?, if so what are we supposed to do? my car is only 2002, and I love it, do not want to give up on it
07 Aug 2015 07:41 #149277
Replied by mlines on topic transmission control module
Chassis/VIN number and I will investigate
07 Aug 2015 09:26 #149285
I have spoken to my Suzuki contact.
Most controllers are still available and I can get them, they are not cheap however!
Not only that but the contact said that even for the discontinued ones that Suzuki can get "pre-owned" (ie. used) modules in some circumstances. So get me the VIN number and if possible the part number stamped on the module itself
martin
martin
07 Aug 2015 09:28 #149286
For reference we are talking of perhaps £600 to £650 depending on the model
07 Aug 2015 18:54 #149345
by Rhinoman
Replied by Rhinoman on topic transmission control module
What part number is it? I might have one. If not I may be able to repair your TCM, what is supposed to be wrong it?
- jaybe
- Visitor
08 Aug 2015 19:22 #149439
by jaybe
Replied by jaybe on topic transmission control module
Hi, v in number is jsafjb43v00141561 model jimney jlx 1300 auto regards jaybe
- jaybe
- Visitor
08 Aug 2015 19:25 #149440
by jaybe
Hi, the car is in limp mode so I'm told, it is stuck in 2nd gear. Regards jaybe
- jaybe
- Visitor
09 Aug 2015 08:53 #149499
by jaybe
Hi, yes, that is the number on the box, year of car is 2002, has had diagnostic check, at a suzuki dealer, and they said it was transmission control module.regards jaybe
- jaybe
- Visitor
09 Aug 2015 09:01 #149500
by jaybe
Hi, when reading your message again, it says that your man has said that suzuki still have them, which makes sense, as they are still making jimney, but I was told by the suzuki dealer, no longer available regards jeanette
- Thank you received: 252
09 Aug 2015 12:57 #149512
by j999pre
Grey pick up Jimny
Replied by j999pre on topic transmission control module
I may have one but I'm away until the 24th
Grey pick up Jimny
- Mort
- Visitor
03 Nov 2021 00:38 #239821
by Mort
Replied by Mort on topic transmission control module
I have same intermittent module problems. Drops back to second while cruising some times any help would be appreciated and where is module located thanks. Cheers Phil.
- Thank you received: 102
03 Nov 2021 15:12 #239841
by fordem
Replied by fordem on topic transmission control module
Get a proper diagnosis done, in my experience the transmission controllers are not "high failure rate" items and the problems can be related to sensors, wiring and occasionally the solenoids in the transmission.
What model Jimny are you having trouble with?
Time to create page: 0.158 seconds
