Leaving battery out of Jimny - problems?
- Sandspider
- Visitor
Got a flat battery in my Jimny (2000 hard top). I need to take it out, either to replace it or to put it on a battery conditioner. If I take it out of the car for 24 - 48 hours, will I cause problems when I put it (or a new battery) back in? I'd guess not, as the immobiliser must be a fairly ancient design, and hopefully not too sensitive to loss of power...?
The battery has gone fully flat before, and the car seemed to work as normal when I got it going again (after a few hours), but just thought I'd check if leaving it longer without a battery might cause problems?
Many thanks.
- UKDAN
- Visitor
Dan
- Sandspider
- Visitor
I don't mind doing that - I just don't want the immobilliser to lose its settings, or the ECU to reset, or anything like that!
Cheers.
There should be no problem but I know where your coming from with modern micro elecetrickery when it gets a few years old but the Jap stuff is usually pretty good.
- Sandspider
- Visitor
OK, I'll give it a go, and see what happens.
Cheers.
- Thank you received: 260
- Sandspider
- Visitor
Sandspider wrote: That's a neat idea. I don't think I have got any systems then need constant power! (No alarm on the Jimny). It's just to be safe.
I've used that sort of thing on some of my motors, at the very least it saves having to reset radios or whatever.
- markyp2000
- Visitor
markyp2000 wrote: I left mime off for over a month while rebuilding the engine and all was fine
I ask, on these simple little vehicles what can die??
- Sandspider
- Visitor
- Thank you received: 584
Mine has an Optimate connector (fused) that dangles out of the bonnet shut line by the hinge, and has a conditioner connected as I type, currently the voltage is 13.78, been on since I got home from Work at about 7pm last night.
Not too bad as there are 2 extensions between the conditioner (in the shed) and the car (on the drive).
I just have to disconnect the plug, roll up the lead and hide it in a bush by the front door when I drive off.
