Jimny lean spacer help
- Rodden87
- Visitor
- markyp2000
- Visitor
Or remove the 1" spacer from the passengers side
- TomDK
- Visitor
Rodden87 wrote: So after owning my jim for six months I'm getting more annoyed with its lean! Measuring from the top of front shock mount the drivers side is 1 inch lower than the passenger side! My quandary is I run 3 inch kap springs + 1.5 inch spring spacers. I did think about dropping to 1 inch spacers and going to a 2 inch spacers on the drivers side but I don't want to spend loads of cash on different spacers! So I thought about running a extra spacers in the drivers side 15mm wouldn't completely fix the lean but would help or a 25 mm spacers which should sort it although I'm a it concerned about running a 1.5 inch and 25 mm together has anyone tried this before with any success?
Have you tried swapping the front springs? Or are they exactly the same length ?
And, if you are using spacers, why not loose the spacer in the tallest side.
- Rodden87
- Visitor
- markyp2000
- Visitor
Rodden87 wrote: I can't really afford to loose any lift as the tire rub on flex as it! So I would like to know find a way of getting level without touching the other sides if that makes sense and I'm sure kap springs are the same length!
Buy a set of offroad armoury spring as thay have the drivers side made longer to compensate for the lean if you get the 4" lift you can take your spacers out
- Thank you received: 153
- markyp2000
- Visitor
supergaz wrote: ORA won't supply just the springs. Best to call Jimnybits as they will supply the front springs where they have a longer offside front spring.
Well thats just shit so what if i brake a spring i cant get a new one
- TomDK
- Visitor
Who told you that?
I bought ORA springs only earlier this year because I wasn't sure what shocks I wanted and could afford. I ended up buying Rough Country N2.0 from ORA though
- darthloachie
- Visitor
just fit a spacer on the opposite end of the spring so you have one top and one bottom
bits4vits sell a single spacer in either orange or black
www.bits4vits.co.uk/store/jimny/spring-s...y-lean-/prod_43.html
- Rodden87
- Visitor
- TomDK
- Visitor
- darthloachie
- Visitor
