My New Jimny! :)
- hjb_1990
- Visitor
Im new to the forum and just wanted to say hi. Ive just bought my first Jimny and am new to all this 4x4 lark so hope to learn alot from this great site & forum.
I do have a few questions if anyone is up for helping. I have attached a picture of my Jimny below and need to know a few things...
1. I have standard road tyres on my Jimny at the mo (205/70/R15) and i want to get all terrains for it as i will be using it off road for shooting etc... Will it take 16" tyres as it is standard or will it require a lift or spacers? I only ask because 16" seem much easier to come by than all terrains in the above spec... (unless anyone knows of any going cheap!?!?)
2. Can i buy and/or get fitted a towbar and electrics to my Jimny as it doesn't come with one as standard but would be useful for tasks on my shoot. Will it require the bumper to be cut etc... and is it a job i could do myself or is it best to get a garage to do this?
I'm sure there more but i hope to feed from your knowledge over time
![;) ;)](/media/kunena/emoticons/wink.png)
Thanks to all,
Harry
- Dan_w
- Visitor
Welcome to the forum, I am unsure about the tow bar but expect you will easily find one on eBay that will need little work to fit. As for the tyres you can't fit 16 inch tyres without changing the wheels you presently have 15 inch wheels fitted so will have to stick to 15 nc tyres unless you get some new wheels. There are plenty do threads about what tyres fit with and without a lift if you have a quick search around.
- supergaz
- Visitor
AT's here www.4x4tyres.co.uk/advanced_search_resul...der=1&4=18&5=56&6=65
I'd say you would be better to fit some 215/15/15 instead to give a little lift under the diffs.
Going down the 16" wheel route is not worth it.
Towbar here, there may be cheaper but this is the cheapest I found on a quick search.
Fitting a towbar is a doddle for me, but I am an engineer! but a simple socket set is all you should need.
Wiring is also easy, you don't even need a bypass relay on the jimny,but this depends on your electrical abilities.
Instructions here www.bigjimny.com/images/documents/jimny_towbar_install.pdf
However don't use scotch locks, they are BAD! solder connections and use heat shrink for a reliable connection.
- hjb_1990
- Visitor
Are they likely to fit on my wheels and the standard Jimny?
Im clueless in regards to wheels/tyres etc...
Thanks for towbar info... looks good.
- TomDK
- Visitor
Easy job and it seems like great quality.
And no cutting in bumper required. Just need to remove it to install towbar.
- JimnyDan
- Visitor
You will have a great time with the drop top for going shooting, my mate has a grand vitara with a drop top and you can just kneel on the back seats with a rifle out on the roof if your lamping etc
![:) :)](/media/kunena/emoticons/smile.png)
- mudman
- Visitor
- hjb_1990
- Visitor
And once the tow bar is fitted i will be able to use it to go feeding aswell on my little shoot. Other than that i probably wont modify it much more. If i can get the ones on ebay for £150 ill probably give them a go.
Cheers for your help again,
Harry
- Tadpole
- Visitor
- JimnyDan
- Visitor
My jimny sits a bit low going round our shoot ground with 300kg of grain in!
Anyhow, it is a very capable car with just a decent set of tyres
- GuardianAngel
- Visitor
- mudman
- Visitor
hjb_1990 wrote: Yeah thats what we do lamping at night for foxes and rabbits so once i have decent wheels the soft top will be perfect for this with some sort of rest on the roof and someone in the back shooting.
Harry
you may want to think agen on them goodyear AT/R's are not the best on wet grass and sticky stuff think you'll be beter with these tyresdirectuk.co.uk/shop/product-info.php?prodname=&id=16581
