BigJimnyMeet 2024
Whats this?
- doncarlyon
- Visitor
16 Apr 2011 14:40 #15131
by doncarlyon
Whats this? was created by doncarlyon
- Thank you received: 584
16 Apr 2011 14:55 #15132
by facade
Replied by facade on topic Re: Whats this?
Oil coming from the halfshaft is escsping from the swivel housing.
You need to check the swivel bearings (kingpins) for play, (most likely there will be) then change
Top & bottom swivel bearing
Half shaft oilseal
Both these come to about £23 from Bigjimny Shop
You most likely will need a new swivel housing seal, these are about £25 off eBay
So £50 will get it sorted.
There are some guides on here to help with fitting.
Half shaft oilseal
- bluejimny
- Visitor
16 Apr 2011 15:23 #15133
by bluejimny
Replied by bluejimny on topic Re: Whats this?
yes as above matey!
- doncarlyon
- Visitor
16 Apr 2011 15:51 #15135
by doncarlyon
Replied by doncarlyon on topic Re: Whats this?
Ok cool... thanks guys!
Will get it looked it, im off work next week anyway.
- Keefe
- Visitor
16 Apr 2011 16:26 - 16 Apr 2011 16:27 #15138
by Keefe
Replied by Keefe on topic Re: Whats this?
No eBay APP ID and/or Cert ID defined in Kunena configurationHere's your swivel seals.
They're quick at sending too....
K
K
Last edit: 16 Apr 2011 16:27 by Keefe. Reason: spulling mistook
- myers647
- Visitor
16 Apr 2011 16:59 #15139
by myers647
Replied by myers647 on topic Re: Whats this?
Hi mate it will probably be the swivel joint seal, this is a ten minute job to change. Just make sure you remember which way the three seals go when you put them back on you will know what I mean when you take it off.
Have a look on the HOW TOO part abou how to change the KING PIN bearings this shows the seal.
Good look
James
Good look
James
16 Apr 2011 23:51 #15143
by kirkynut
Replied by kirkynut on topic Re: Whats this?
It's the axle tube oil seal that's leaking due to excessive lateral movement of the half shaft within it caused by excessive wear in kingpin or wheel bearings. Not the swivel seal as that keeps stuff out not in.
Get some new kingpin bearings from Martin which will come with the oil seal.
Then follow Martin's fitting guide and all should be well!
17 Apr 2011 02:03 #15144
Replied by mlines on topic Re: Whats this?
Yes - its NEVER the large swivel seal. This seal is really designed to keep dirt out, not grease/oil in. The joint inside is "dry" (ok - so it has grease packed into the CV and a small amount around the ball), therefore any leaking is a problem. The problem is usually the King Pin bearings themselves.
If you are doing the bearings you can replace the large seals but more often than not a quick wipe with an oily rag will bring them up nicely.
- doncarlyon
- Visitor
17 Apr 2011 06:58 #15146
by doncarlyon
Was told the car had a full front axle rebuild before i bought it, so looks like this may not be the case...
17 Apr 2011 08:03 #15148
by facade
It may have had the swivel housing packed full of grease by mistake...
Check the bearings both sides whilst you have the jack out.
- myers647
- Visitor
17 Apr 2011 09:22 #15150
by myers647
I stand corrected both times iv changed t king pin bearings wen iv had an oil leak, but iv also replaced the large rubber seal as these where both well worn aswel.
- doncarlyon
- Visitor
17 Apr 2011 16:04 #15171
by doncarlyon
May be clutching at straws here but...
The screen wash tank keeps emptying itself but i cant see where from, is it just a coincidence that this is directly above the area which looks like its leaking? hmmm
Time to create page: 0.121 seconds
