Dave’s long-term Lil’Bugga Buggy Build
- Thank you received: 1627
19 Apr 2022 06:25 - 19 Apr 2022 06:27 #242992
Do you know what rate these springs are, as looking at them they seem quite beefy? For this to work smoothly you need fairly weak springs as helpers so that they are fully compressed at normal rode height. Unless you are actually wanting them to work as a progressive rate compound system? It's just if they are too stiff then you will not have any movement in the slider section except at full compression. Ideally it needs modeling with some idea of the final weight of the buggy.
Replied by Lambert on topic Dave’s long-term Lil’Bugga Buggy Build
Just browsing eBay, as you do, and some second-hand coilover springs popped up…
bid gone in
looking at stock suspension -
the cone with the bump stop on the bottom inside the spring looks to be 2”+3” long, and these are about 5.5” long, so should compress to 2” to 3” ?
(ones is 6.5” long but Mr.Angry will soon sort that
And they’re 2.25” internal diameter so will slip nicely over some 2” OD seamless tube roll cage off cuts I’ve got lying round, which will make the outer tube of the ‘pistons’ I’ve proposed above…
Last edit: 19 Apr 2022 06:27 by Lambert.
- Thank you received: 919
19 Apr 2022 13:29 - 19 Apr 2022 13:33 #242996
Replied by X8GGY on topic Dave’s long-term Lil’Bugga Buggy Build
Too late! I won them last night for £22 delivered, so worth a look and a play…
When I originally zoomed in on the eBay hi-res photo I reckon they’re wound from 8mm wire and the coils are 20mm apart… they’re 5.5” long and I need them to compress to 2.5” - 3” to equal the stock position of the bump stop cone mounting, which I reckon to be about 4” below the spring seat in the photo now on the previous page, so the bump will actually be more like this -
To give me more droop and upward articulation with the long shocks (29” open, 15” closed so 14” of available travel not that I’ll need that much! Not with stock radius arms and narrowed axles…,)
So in my awful sketch there’s still another 2” of unassisted droop still available…
Last edit: 19 Apr 2022 13:33 by X8GGY.
19 Apr 2022 13:37 - 19 Apr 2022 13:46 #242997
It’s just an idea for me to play with whilst I’ve got time on my hands (mind) to mull it all over in hospital, and winters experimenting and building in the man cave…
Last edit: 19 Apr 2022 13:46 by X8GGY.
19 Apr 2022 16:31 #242998
That's ok then. And it's not exactly breaking the bank at that price. Totally agree that keeping the mind sharp is the trick for being incapacitated, I was just the same when I hurt my back.
- Thank you received: 82
21 Apr 2022 19:14 #243043
by Dirtbird
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
Replied by Dirtbird on topic Dave’s long-term Lil’Bugga Buggy Build
No you just need a Jimny
21 Apr 2022 19:15 #243044
by Dirtbird
Dave just looking at the drawings reminds me of a war movie where the guys are drawing up an escape plan .........
22 Apr 2022 16:42 #243063
New blog entry today, again to relieve the boredom in hospital… considering all the controls I’m going to need to consider how to do them and where to locate them for ease of use…
lil-bugga.com/2022/04/22/controls/
22 Apr 2022 19:24 #243064
by Dirtbird
Dave, is it going to be a crawler?
22 Apr 2022 19:34 #243067
Crawler buggy inspired… but on the cheap using as much as possible standard Jimny parts as they’re readily available and inexpensive, home engineering too, this page explains where I’m heading…
lil-bugga.com/2022/03/26/inspiration-2/
and this one
lil-bugga.com/2022/04/07/developing-ideas/
So tube frame single seater, few years work based on the Boogie’s build and my current health issues?
Purely off-road so I don’t have to comply with anything although I have been reading the AWDC’s rules and class system to maybe head that way a bit as well as ‘Laning The Boogie…
and this one
22 Apr 2022 19:42 #243068
23 Apr 2022 12:13 #243087
Rear Steer Idea -
lil-bugga.com/2022/04/23/rear-steer-idea/
Apologies (to Martin) for external links, saves me copying and pasting, and clogging the BiJimny web space with all my build photos
24 Apr 2022 11:34 #243123
by Dirtbird
Dave hope your in good form . Dave i think there is a group of you here who should meet some weekend up in the moors and start a group called "Jimny Space X" Id put Les , Riccky your self and a couple of others together and see what would come out of the mix.
The task or mission would be to design out the niggles of the Jimny .
Like sore right knee from the driver door card.
Chassis mod for Clutch change.
Im looking forward to the new project as the last build helped me learn fabrication skills and ideas and the idea that it can be done.
Keep the post flying and thanks for sharing.
Time to create page: 0.246 seconds
