13 Jun 2019 04:08 #209908 by Lambert
Hope your dad is ok!
  • X8GGY
13 Jun 2019 05:59 #209910 by X8GGY
Thanks. lambert ;)
  • X8GGY
16 Jun 2019 13:16 #210027 by X8GGY
No work on the buggy today :(
As I had to do a quick fix on the Daily Driver my Gold Jimny - www.bigjimny.com/index.php/forum/18-buil...iver?start=60#210026
Dave ;)
  • X8GGY
19 Jun 2019 16:51 - 19 Jun 2019 16:54 #210136 by X8GGY
Few hours spare this afternoon B)
BEFORE -
AFTER -
Old rubber bushes removed (lovely job... NOT!) and radius arms wire brushed and ready for paint...
And then SuperPro poly bushes going in...
Last edit: 19 Jun 2019 16:54 by X8GGY.
  • X8GGY
10 Jul 2019 21:09 - 10 Jul 2019 21:16 #210867 by X8GGY
Bit more towards the buggy today...
Painted the radius arms and the axle casing twice, then fitted the SuperPro poly bushes into the radius arms, and then fitted them to the axle casing -
Replacement diff (4,3:1 instead of 3.9:1) also painted (on the floor)
Ready for reassembly / rebuild soon...
Slight oddity... the bush kit I bought (off myself as it was left in B4V stock) was a castor corrected kit, but the buggy is only having a minimal (1.5"~2") lift so won't need it, so I chose to use them to reposition the axle slightly forward to help clear the firewall...
Last edit: 10 Jul 2019 21:16 by X8GGY.
  • X8GGY
04 Aug 2019 17:00 - 04 Aug 2019 17:04 #211813 by X8GGY
Back to the buggy today... after first fixing the Gold daily driver (replacement panhard rod bolt for the MOT retest) and S200KYS (new JimnyBits front panhard rod fitted to go with the re-affixed panhard bracket! :ohmy:
Front axle casing ready to go back under... freshly painted (a few weeks ago!), JimnyBits front shock guards, SuperPro poly bushes, breather elbow tapped and fitted, shocks are Monrow Adventure Grand Vitara rears which are +1.5" over Jimny ones...
Radius arms reattached, with JimnyBits guards...
Front suspension fitted... fresh new standard front springs with spring spacers on top, bump stop spacers and poly bump cones, Monroe shocks as previously mentioned... and SuperPro castor correction bushes set to push the axle forward rather than re-align it..
All in place with a JimnyBits front adjustable panhard rod...
Next step will be the transmission, so a later VVT diff is painted and ready to go in to adjust the gearing for the bigger tyres - 4.3 rather than 3.9's, new bearings and seals everywhere, and get the wheels and tyres back on... push it out to get the feel of it, where to cut the front body panels off ;) etc, and tidy the garage and push it back in again...
Transfer box then needs to come out and get armoured, new brackets and a bucket...
And then spend the winter fettling it into a buggy shape B)
Last edit: 04 Aug 2019 17:04 by X8GGY.
Time to create page: 0.255 seconds
