14 May 2014 19:38 #115245 by maverick
Bits4Vits wrote:
panosd wrote: Very nice.
The polybush is from your shop?
And an advise, try to see if you can fit a balljoint to the arms bush position, at the chassis side of the arm.
Mach way better articulation. I have in mine and 3 years now works perfect.
And a ''stupid'' question about breaks,
if we convert the rear breaks from drums to disk's the abs is no longer engaged, correct?
I want to go for rear full foat axleshafts and disk break convertion but i dont't want to lose abs.
With fedima cross tyres has saved me a lot from accidents.
Yes, poly bushes came from stock... I did pay for them though ;)
Hmm, yes, presume the ABS would still work with disks on the back?... someone more knowledgeable will be along soon...
I think that the ABS would still work on the rear if Disc were fitted, as there is a gizmo that goes into the axle
JalapeƱo, IISY?
The topic has been locked.
  • bluejimny
  • Visitor
  • Visitor
14 May 2014 20:47 #115254 by bluejimny
Replied by bluejimny on topic Dave's (Bits4Vits) Jimny 'laner Build...
yes your right ABS will still work on rear disc conversion, as the abs pickup ring is on the bearing retainer thats inside the axle
  • JimnyKarl
  • Visitor
  • Visitor
14 May 2014 22:22 - 14 May 2014 22:24 #115256 by JimnyKarl
Replied by JimnyKarl on topic Dave's (Bits4Vits) Jimny 'laner Build...
Looking real good Dave hope to see it and meet you at the Jimny get together later this year. watching this thread with interest.
Last edit: 14 May 2014 22:24 by JimnyKarl.
  • Bits4Vits
  • Visitor
  • Visitor
18 May 2014 21:55 - 18 May 2014 22:13 #115669 by Bits4Vits
Replied by Bits4Vits on topic Dave's (Bits4Vits) Jimny 'laner Build...
Thanks Karl ;)
Bit more today...
ORA Front Radius Arms, JimnyBits adjustable panhard rod...
Installed with just a bit of fiddling to get the bolt through the guard, spacer washer, chassis mount, bush sleeve, chassis mount, spacer washer, guard... soon sorted! B)
Offside with pipes again running down the girder-like ORA radius arms B)
Panhard rod in (with BigJimny bolts)
+3" JimnyBits Springs, +3" ProComp ES1000s, bolts, sugar-free Relentless to keep me going! ;)
Tyres on, stolen from the Zukhini Vitara, with many thanks from Brett 'Maverick' on here who came to help... thanks matey! ;)
Inner plastic wings need trimming when I work out where the ORA winch bumper will sit...
The whole purpose of today... get the suspension on enough to get the Jimny into the garage so that I can work on it in all weathers...
More soon! B)
Last edit: 18 May 2014 22:13 by Bits4Vits.
  • gaz3359
  • Visitor
  • Visitor
18 May 2014 22:31 #115674 by gaz3359
Replied by gaz3359 on topic Dave's (Bits4Vits) Jimny 'laner Build...
Good progress dave coming along loads.
19 May 2014 22:12 #115787 by funkyjimny
31's ready for me then Dave :) going to look great on my jimny !
Gary
  • Bits4Vits
  • Visitor
  • Visitor
19 May 2014 22:17 #115788 by Bits4Vits
funkyjimny wrote: 31's ready for me then Dave :) going to look great on my jimny !
Gary
Yes mate, temporarily on Zukhini -
For ease of transfer to your Jimny... hope they fit! they look big on the Vit'!
  • Bits4Vits
  • Visitor
  • Visitor
26 May 2014 19:58 #116388 by Bits4Vits
So, today (Bank Holiday Monday, I had a few hours off... I spent yesterday - Sunday - lazing around and recouperating :S ), I started fitting the ORA front winch bumper...
A few photos here, more in my own blog.
Fitting the brackets -
Test fit of the bumper -
Winch on the back of the bumper -
Fits! JUST!
Hmmm, a bit too tight -
So took some more metal off -
Flipped the free-spool over -
Getting there! -
Wiring next, and a dashboard control switch... B)
26 May 2014 20:37 #116395 by funkyjimny
The bumper brackets look just like the ones on my ARB bumper.
Gary
  • Bits4Vits
  • Visitor
  • Visitor
28 May 2014 14:25 - 29 May 2014 09:44 #116522 by Bits4Vits
My rocklobster box came back from the wizard of all things gearing today, many thanks to Rockwatt! B)
It went off as I mentioned to Rich that the bolts didn't fit through the cradles holes, apparently sometime in it's life it's been drilled and re-tapped to 10mm, whereas the case should have 8mm mounting holes... Not happy with this, Rich took it back - as he rightly said, it would have weakened the box's mounts - and changed half the case for me... B)
While it was there... ;) I asked him to fit my new speedo ring (27 teeth, should be right with my 235/75s I hope) and the pickup mount, and change one of the flanges for me which had the wrong bolt hole pattern (PCD)...
And, errr... hee hee, change the internal selectors so that I can have two-wheel-drive-low when needed ;) Here's the shift pattern etched into the top of the box...
What a STAR! Cheers Rich... err - "Rockwatt" B)
To remind me... will put a copy on my dashboard eventually... ;)
Last edit: 29 May 2014 09:44 by Bits4Vits.
  • 2014Nathan
  • Visitor
  • Visitor
28 May 2014 18:04 #116530 by 2014Nathan
Replied by 2014Nathan on topic Dave's (Bits4Vits) Jimny 'laner Build...
Looking real good now buddy!
  • Bits4Vits
  • Visitor
  • Visitor
28 May 2014 18:30 - 28 May 2014 18:36 #116533 by Bits4Vits
2014Nathan wrote: Looking real good now buddy!
Coming slowly... still lots to do...
  • Finish the winch/wiring, and fit Odyssey battery in ORA mount
  • Fit the Rockwatt Rocklobster box
  • BigJimny Breather Kit
  • Rear ARB Air-Locker
  • Front Rob Storr 26 Spline Shafts for:
  • Calmini Front LSD (pinch from Zukhini)
  • Rear ORA Bumper (silver to match front one and o2 trim)
  • ORA made internal Rollhoop
  • My trusty bucket-seat (pinch from Zukhini)
  • CB (pinch from Zukhini)
  • Roofrack / soft-top protection
Probably forgotten some bits?...
Last edit: 28 May 2014 18:36 by Bits4Vits.
Time to create page: 0.246 seconds
