BigJimnyMeet 2024
1.9 td Jimny
- chris2010
- Visitor
05 Nov 2013 22:14 #89556
by chris2010
Replied by chris2010 on topic 1.9 td Jimny
Using a Standard LDV Clutch it bolts straight on.
the LDV Engine Mounting/Gearbox Bracket Requires Modifying to fit around the Turbo Return Pipe and Feed Pipe.
Standard Lucas Stop start solenoid is coded so this was replaced with a standard on/off unit.
More Pictures to follow once i Progress a little further
- chris2010
- Visitor
05 Nov 2013 22:16 #89557
by chris2010
PHOTO 3 SHOWS THE LDV ENGINE MOUNTS WHICH DOUBLE UP AS ENGINE ADAPTER FOR PEUGEOT TO LDV GEARBOX.
PHOTO 4 IS THE MODIFIED ENGINE MOUNT TO CLEAR OIL HOSES
- chris2010
- Visitor
07 Nov 2013 23:13 #89911
by chris2010
Fuel tank had been dropped and fuel pump removed and modified
thrustbearing turned up today, gear box has been trial fitted onto the engine
Overall length from engine mount to end of gearbox is actually 130mm shorter on the pug block in compared jimny
- chris2010
- Visitor
10 Nov 2013 11:03 #90177
by chris2010
Done a little yesterday , some pics to follow
Fuel filler adapted to take diesel hose
Engine mounts on diesel engine bolted up to check fit
Gearbox has threaded push fit elbow tapped in breather ,
Front and back axle breather push for elbows fitted ready for breather hoses
Going to drop transfer box and tap the transfer box breather next week,
Things to do in week, wait for plasma cutter to turn up , cut the original mounts on chassis off, drop the engine and box in and see how she fits in ,
- steffan
- Visitor
10 Nov 2013 12:02 #90182
by steffan
Replied by steffan on topic 1.9 td Jimny
Plasma cutters are the future
- chris2010
- Visitor
10 Nov 2013 15:02 #90204
by chris2010
Plasma cutters make easy neater jobs ,
With the cost of them getting so low. I find they are essential to any
One wanting to fabricate bits and bobs
- whittleos
- Visitor
02 Mar 2017 23:40 #178763
by whittleos
Replied by whittleos on topic 1.9 td Jimny
did this ever get finished ? .. i have just taken a 1.9 td engine out of a jlx viata inc gear box . removed its transfer box from the back and mounted it into mine gear stick lines up engine sits nice has nice notch in sump for axle as standard . easy and fast . and no issues of clutch or gear box pooping its pant's . have it running to t-case transfer box using sj small prop
Time to create page: 0.091 seconds
