Challenge trayback build
- aniesigh
- Visitor
come up with a plan, if i move the box up a set of holes the tie bar now has clearance on the pitman arm, also means theres room to put the original alternator back on (just) which is handy and also means that getting the steering joints onto the box will be easier.
then a mount in the tie bar to take the rose joints from ORA and the pitman arm adapted to double shear for a similar mount at that end and should be ok
so many things to think about in this there was always going to be things that didnt work first time! ah well keeps me out of trouble and my bank balance in trouble
oh and came up with a plan for the body
- X-Eng Simon
- Visitor
Si
- darthloachie
- Visitor
- Thank you received: 360
even those black rubber side protectors are about £60 new - clean them up and apply some adhesive tape and there's £25 straight away.
there's definitely a few quid lying there and even if you can't be bothered, sure you'd know someone who'd list it as a shell break, deal with enquiries and sell bits for a commission
............ think I'll have to build a bigger shed at my allotment and start Jimny breaking
- adamatdraycott
- Visitor
Halford wrote: even those black rubber side protectors are about £60 new - clean them up and apply some adhesive tape and there's £25 straight away.
Depending on condition i'd buy them!
- aniesigh
- Visitor
will have a look at what condition the black trims are in, and the roof bar end caps are available
rear lights will be sold, and anything from the interior, and the rear windows then the back half will be weighed in unless someone wants to buy it to make a jimny trailer
Front end i'm not sure what im doing with 100% yet, but it needs to be extended whatever happens
- Sponnie
- Visitor
By god those LJ axles are HUUGE!!
- TomDK
- Visitor
What ever happened to this build ?
- aniesigh
- Visitor
Adam
- TomDK
- Visitor
Any news on this build ?
Did you find a solution to the sump/diff problem ?
I found this on Ebay, don't know if it's of any use
- aniesigh
- Visitor
thanks for the link on the sump, i sort of have one lined up but the chap doesnt seem in any rush to remove it for me, but as this chap has it off i can ask him for some dimensions to find out if it will actually clear. i think even these sumps will be close but was just going to buy one but this might be a better way forward, cheers! hows your build?
Adam
- TomDK
- Visitor
As for my own Jimny.. Well, just been at sea for the last 2 months.
But I got a Goodwinch TDS 9.5c mounted, also OME 2" lift and 235/75-15 Insa turbo special tracks. Now on a bit of a standstill though. I've also got a house that needs some work (lots of work )
Also, I think I'm going back to my original plans and making it not road legal. More options for engine, suspension
Just not sure which engine... The 1UZ-FE is certainly something, but a lot of work.. So I considered perhaps trying to find a complete GV 2,5 V6 engine, with auto-gearbox and transfer.
