Challenge trayback build
- darthloachie
- Visitor
- frede.gv1
- Visitor
- aniesigh
- Visitor
X-Eng Simon wrote: Looking good!
Good choice of shocks too.
Mine has moved forward a bit - but nothing terribly photogenic, just the fiddly bracket making kind of thing. I spent a day last week making a beautiful gearbox mount with lots of dimpled holes and perfect folding. It looked like the kind of thing you'd be proud to post on pirate4x4. Came to fit it - then discovered I'd made the mirror image of what I needed! I exacted terrible revenge on it with the fly-press which made me feel better! I made it's replacement this evening in half an hour without any dimples or niceness - but at least it fits!
Si
Gutted! been there before, when i cut all the chequer plate for my SJ's trayback i made a mirror image of what i needed! unfortunately the tray wasn't quite symetrical so i had to re-do the lot! wasn't in the best of moods after that! do you use a fly press to punch the dimple dies? always liked the look of dimple dies but never even thought about how they were done for some reason
R_ogilivy, yep i will be in mod as have locking diffs front & rear and will have at least 2 winches, hope to see you there! and yeah no worries on trayback advice, but looking at what you've already done i can't see you'll need it
Darthloachie, thanks, always a motivation boost
Frede.gv1, what do you mean by K-link? i'm guessing triangulated 4 link or 3 link with A frame? if so then because both the 4 link are harder to setup, and take up more space in places space is critical, and an A-frame setup means another type of joint would be needed for the A-frame which means more spares to carry. 3 link is very much tryed and tested and easy to setup, i'm not overly adventurous on suspension designs (particularly not as this is my first one!) if you wan't adventurous suspension design check out Si's build or Zero over on difflock
Adam
- neofitou
- Visitor
I think k link is fine in the rear, but I would rather 3link the front to maintain caster though more of the cycle. This is the setup I might do this on my next build too, but only 33" tires as I'm going to use Jimny Axels, I'm going for the narrowest track, as low as I can to suit the terrain I drive.
- suzuki jimny fella
- Visitor
- aniesigh
- Visitor
Axles all braced up and mounts strengthened
Chassis flipped and welded/ mounts strengthened
Made the link bars and built up the weld on Johnny joints, really glad I bought the tool to assemble them, sure I could have done it with some sockets and threaded bar but it made It really easy to put them all together!
Axles / link all painted up then axles built
Then theres a big gap in photos…but engine mounts made and welded, gearbox cross member made, and cradle to mount and protect the transfer box made as it was looking rather vulnerable!
Then put it all together and you get a rolling chassis!
Gearbox cross member fouls on front prop so will need to tweek that
And sump will hit front diff which I already knew about, not 100% sure whether I will try make a new one myself or try a soarer one but they seem to be abit rare and fetch silly money so maybe plan A.
Cut the exhaust flanges off so I can reposition them so they no longer foul the chassis
Nearly a 90degree departure angle even with these tyres
So all in all I had a good day today putting it all together! Feels like I’m getting somewhere at last, couple of hiccups along the way though!
A poor photo but you get the idea
Oh and this
It seems gravity had a go at making my sump fit, still no joy!
Got this today too, never seen a cool looking grinder disc before! Looking forward to giving that beast a try!
That’s it for now, just got to plumb the exhaust brakes and cooling, make the panhards, fit the body, trayback it and extend front wings, wire it up, fit the winches, blah blah blah right that’s me depressed again!
- r_ogilvy
- Visitor
- Visitor
- X-Eng Simon
- Visitor
It's nice to see that you've been plagued with clearance issues too! I re-made my front prop three times - with the final version being made from a Land Rover half shaft 31mm - and now I have 2mm clearance on the sump and 1mm on the front A frame under full compression. Not much, but enough.
Today I made the exhaust with lots of complicated bends - a real pain in the bottom!
I'll post some piccies soon. All I have to do now is plumb the brakes, connect the handbrake and wire up the lockers - then it's drivable. When the weather gets better, I'll make the external cage & winch mountings. Tube bending needs more space than I have indoors.
Si
- aniesigh
- Visitor
Si, haha yea i think doing the type of build we've both undertaken theres always going to be loads of clearance issues, i'm sure there are easier ways of getting around them but the most time consuming tend to be the ones with the best end result...which is a pain!
i'm not looking forward to doing my exhaust, the N/S shouldnt be a problem but O/S has to go over the transfer box without interupting the shift mechanism thats a headscratcher for another day though
looking forward to seeing how yours is progressing
- viciouspenguin
- Visitor
If the devil wanted a Jimny, I think he'd give you a call.
