BigJimnyMeet 2024
It's not a jimny so I need help.
- Thank you received: 1761
26 Jan 2024 07:15 #253765
It's not a jimny so I need help. was created by Lambert
Hi clever people I need assistance. We bought our 2018 land cruiser aged 2.5 years old from our local main dealer. When we bought it we told them that it was only really going to be used 4 times a year for its intended use of being our tow barge and that the rest of the year it would get occasional use as a Sunday car mostly because of the fuel consumption and it being a big old Hector for our country roads. When we first look it out we had to wait because the battery was flat. Long story short it's now on it's 4th battery and I have been told by the dealer to keep the voltage above 12.2v to protect the battery. The car has been back for leaking electricity multiple times for weeks at a time. I'm able to track the voltage drop over a week of inactivity using my tracking system. I have had a multi meter over it myself, the dealer has had increasingly indepth diagnostic tests on it, its been under an independent auto electrician and has finally been referred back to Toyota UK for 2 separate diagnostic sessions. They are saying they can't find anything out of tolerance and are now offering a trickle charger. This is to my mind an admission that something is wrong that they cannot find. I am resistant to a charger as one it's a sticking plaster solution and two the car lives with my parents and they hardly have the dexterity or technical aptitude for it and honestly it is a 6 year old land cruiser it shouldn't be necessary to trickle charge it if it's done less than 50 miles a week. The alternator on these are apparently designed to only deliver 13.8v as an efficiency measure instead of the more usual 14.4v and the battery spec is a single 75Ah by virtue of it being the van version not the big twin battery car version with all the extra computers. I'm partly venting but I'm also after some insight into what I have to do to make it work properly. And no I'm not dailying it instead of the jimny just to keep it charging.
- Thank you received: 552
26 Jan 2024 08:30 - 26 Jan 2024 08:33 #253766
by Scimike
Replied by Scimike on topic It's not a jimny so I need help.
As an owner of 3 classic cars that get used infrequently I wouldn't expect the battery to remain healthy between use without the aid of a trickle charger of some form. These vehicles are old school, with no parasitic loads or a very low load, radio memory etc. The alternator's aren't smart, stuffing over 14v and as many amps it will take into the battery. Even on these, 4 starts a year without battery assistance would be pushing my luck.
No agreeing with your dealer, but modern cars have a higher parasitics loads and you are at the mercy of the " smart alternator map" however that's written. You also have natural battery discharge which everyone forgets, this increases with battery age and it's construction. I would have to go down the logging route, recording the parasitic load over a few days and doing some rough calculations based on this / battery capacity/ natural discharge to see if the Land cruiser has issues. But as we speak today my logging DVM is bust and the software won't run on windows 10, so it's no longer an option.
So I would just fit an external smart charger ( Aldi etc) or a window solar panel to it and go for a drive in the Jimny. If you go solar get one above 6W, the low power ones don't work well in the UK, not enough sun
Last edit: 26 Jan 2024 08:33 by Scimike.
26 Jan 2024 09:27 #253768
Replied by mlines on topic It's not a jimny so I need help.
The new Jimny and our 2015 Swift has power management for added economy and this sounds like what your dealer was referring to.
This detects the load on the engine, particularly at first start up and switches off systems to give the engine a chance to warm up. One of the systems it manages is the alternator. This gets turned off during the first 10 minutes or so.
You may recall that a new Jimny owner in Australia had real issues with this as his battery never charged. He only drove very short distances and with the Aircon running etc. the car never switched over to charging the battery. This destroyed a couple of batteries for him.
We use a C-Tek charger on our vehicles as, on average, they do not get regular daily use. This not only charges but also conditions the batteries. The connector on the C-Tek disconnects if you accidently drive off with it connected.
- rogerzilla
- Visitor
26 Jan 2024 09:34 #253769
by rogerzilla
Replied by rogerzilla on topic It's not a jimny so I need help.
Can you disconnect the battery earth lead? Depends in the risk of theft where you live (no alarm).
26 Jan 2024 09:57 #253771
Replied by Lambert on topic It's not a jimny so I need help.
It's not that I only use it 4 times a year but on those 4 days I want it to work without any intervention from me as they are my 4 busiest periods and I don't have time for messing with cars. The rest of the year I would like to be able to choose if it's the appropriate vehicle to take rather than feeling I have to use it every week to stop it going flat.
I have suggested a disconnect for the battery but apparently that's really not good for the computers.
The efficiency programme seems to be different to suzuki in that it does charge from engine start but I can't find any more information on what else it does.
26 Jan 2024 10:08 #253772
by saxj
Replied by saxj on topic It's not a jimny so I need help.
My gen 4 stood for a month and it's battery was completely drained. The only parasitic thing above standard is national luna battery monitor.
- Thank you received: 372
26 Jan 2024 10:12 #253773
Replied by DrRobin on topic It's not a jimny so I need help.
I have had a lifetime's experience of a flat/draining battery on my Boxster. For the first 8 years of my ownership it eat a 75-80Ahr battery in about 18 months, didn't matter what battery I would buy it would go through them.
Boxsters have a reputation for a high current draw when they are sitting there doing nothing and after a week it switches the remote central locking off to save power, that doesn't work. It will flatten a fully charged battery in about 5 weeks, just stood there. The Jimny is pretty much the same.
I bought a solar panel (for both cars), as Martin says get a big one, mine are mono-crystaline 20W panels and still don't really maintain the charge, but do help.
I also bought a Ctek MXS 5.0, that helped bring the charge up after the car has stood for 2 or 3 weeks without use.
After years of struggling with my Boxster I finally found out what was the main problem, the alternator started to go and was clearly faulty for some time because when it had a new alternator and then another new battery, that one lasted for around 4 years and was replaced in the early days of Covid and is still going strong nearly 4 years later.
I also bought a battery tester, Ancel BA201, it shows state of charge (just voltage really), but measures starting current (CCA), alternator charging and ripple, they are very useful. I don't use it much but tested a neighbours battery and alternator the last week, he was having starting problems, his battery was a bit down (50% charge) but the CCA was only half it's quoted value. He borrowed my Ctek and after a full charge his car is now fine.
The other thing I did on both my Boxster and Jimny was to measure current draw with the car locked and no lights on. You can do it with a multimeter on a current scale by inserting in line with the battery lead (don't try to start the car). My Jimny measured about 50mA after everything had switched off. I am lucky I also have a DC current clamp, so don't need to disconnect anything, but these are a bit expensive for every day DIY use.
50mA per hour is 1.2Ahr per day, you can see how the Jimny battery at 45Ahr will discharge in just over a month. My Boxster was significantly more than that, about 1A for 30 mins after you lock it, then falling back to around 150mA for a few hours before dropping a bit. No wonder it flattens it's battery.
Not been funny and you might not want to say, but do you lock your Land Cruiser, if not it will draw a lot more current and it gets even worse if you leave the keys in the ignition, but not switch on.
I would suggest measuring the current consumption with it unlocked (no lights on) and then locked. If the current is high, check it on the forums and see if it is normal.
If it is normal, then Roger's suggestion of disconnecting the battery, or pulling the main fuse is the only way, unless you want to trickle charge with a Ctek, it's what I used to do with my Boxster when I wasn't using it for a few weeks.
Robin
Robin
26 Jan 2024 10:29 #253775
It's always locked I don't trust the natives. As for all these tests that's why it is and has been back at the dealer and I have to trust they are trying to help me. And as I said I don't want them to give me a charger for it as that's only masking the problem and I don't have the time to turn up at my parents with little notice just because they are wanting to take the car out and I have to come and sort it for them.
I would almost be inclined to shift it on but then what do I buy that will do what it does in the same footprint and won't bankrupt me. I'm just feeling a little bit painted into a corner with no obvious way out.
26 Jan 2024 11:41 #253778
Good luck with the dealer. Unless it is an easy fix they will do whatever is quickest/cheapest for them and if they don't employ an auto electrician it will be a trickle charger.
Robin
Robin
26 Jan 2024 12:48 #253780
To be fair the dealer is being very accommodating. It now with Toyota UK.
26 Jan 2024 12:59 #253781
by jlines
Replied by jlines on topic It's not a jimny so I need help.
When it’s fixed defo get a charger on it like a Ctek if it’s not being used daily. Doesn’t take long to flatten a battery especially on newer vehicles which require more power for their tech etc. On the Rangies you can flatten the stop/start battery within a week or so of the car not being used. Also I noticed on my old evoque the battery would become sluggish after a week of sitting. At my our tractors/forklift struggle mainly because they don’t run very far so don’t get the chance to charge up.
- Roger Fairclough
- Thank you received: 194
26 Jan 2024 13:33 #253782
by Roger Fairclough
Replied by Roger Fairclough on topic It's not a jimny so I need help.
Using a vehicle only 4 times a year is not what it was designed for, so accept that it will do the things that you don't want it to do and sneak round the corner and out flank it ie fit a C-tek or similar and leave it permanently on charge.
Roger
Roger
Time to create page: 0.162 seconds
