- Forum
- Suzuki Jimny
- For Sale and Wanted
- Jimny Gen-33 Rear Fully Floating Rear Axle Kit - £800 + postage
Sell your bits!
- Thank you received: 116
31 Aug 2021 11:17 - 01 Nov 2023 12:28 #238055
by maverick
Jalapeño, IISY?
FOR SALE – a Fully-Floating Axle Kit for a Suzuki Jimny Gen-3 (1998-2018) Maybe the obvious question here is “What is a Fully-Floating Axle”? To do this you need to understand what a non-Floating Axle is first, generally known as a Semi-Floating Axle.
The “semi-floating axle system” is very common on the rear of most 4WDs. It consists of an axle shaft on each side that is splined on the inner end where it mates to the differential and has a wheel flange where the wheel studs mount at the other end. This assembly typically mates to the end of the axle housing using some type of bolted flange arrangement. The axle shaft also rides on a ball bearing out at the end of the axle housing – in the Suzuki Jimny this is a weak point, as most Green Laning and Off-Roading Jimny owners know too well and often have to replace a Rear Wheel bearing as little as once per yer or even 3 to 4 times a year depending on heavy use.
The “Full-floating axle system, is where the axle shaft only serves to transmit the rotational torque from the differential out to the wheel. It does not carry the weight of the vehicle as a semi-floater does. On a full floater, a spindle is attached to the outer end of the axle housing. The wheel hub is mounted on this spindle and rides on tapered roller bearings. It is this assembly that carries the vehicle weight. As such, a full-floating axle system is considerably stronger than an equivalently sized semi-floating system.On the semi-floating rear axle system you break or have a bearing fail, then you either have a spare shaft with you to use (on a Jimny with drum brakes this is time consuming, and not something you would like to do when out Green Laning or Off-Roading). If you do not carry spare shafts, then you will have to call for the big Yellow Taxi and get recovered to home.On the Full-floating rear axle system you break or have a bearing fail, then you can easily replace the bearing hub whilst out Green Laning or Off-Roading, perhaps in just 15mins with the right tools with you.Our Fully Floating Axle Kit uses the Suzuki Jimny Gen-3 Front Hub/Bearing. As we all know the front bearing is much larger and stronger than the slim rear half shaft bearing and therefore last considerably longer. This gives the benefits of much larger wheel bearings at the rear, increasing their service life and being easier to replace. It also standardises the bearing and bearing carrier used on all 4 wheels of the car, meaning only one spare need be carried to cover any wheel.Braking is using a Jimnybits.com disc conversion kit, which uses Renault rear callipers and Jimny front discs. This guide presumes the reader already has the Jimnybits/Renault rear disc conversion kit fitted. The adapter plates are designed specifically to work with the Renault callipers and carriers. The adapter plates are ABS compatible.
Our Fully-Floating Axle Kit t is supplied with: ·
2x Machined adapter plates with oil seal·
2x 26 spline HD shafts (rated up to 400BHP)·
4 M10 bolts/washers·
4x M8 bolts/washers·
1x M6 nut/bolt/washers
Parts required in addition to the conversion plates and shafts, source and supplied by you.
2x Jimny front hub assemblies comprising of:
2x wheel spindle mounts (note these differ if for ABS or non-ABS vehicles)
2x bearing carrier and bearing (note these differ if for ABS or non-ABS vehicles)
2x wheel bearing locknut and washer
2x brake disc backing plates (optional)
2x Front Jimny vacuum hubs and gasket (MK1 Vitara fixed hubs can be used instead)
2x front ABS sensors (if ABS required)
1x Renault based rear disc conversion comprising of – see JimnyBits.com website:
2x Renault Megane rear callipers (left/right sided). Approx vehicle year 2004-2007
2x Renault Megane rear calliper carriers with sliders, rubbers, and pad shims
2x pair of Megane rear brake pads
2x handbrake adapter tubes
2x handbrake adapter plates
1x set of brake hoses and splitter block
2x Jimny front brake disc (check centre bore is correct for the hubs being used)
1x tube RTV sealant
1x tube thread lock solution1x diff oil for top-up
1x Fitting Guide
Advice and Guidance for hints and tips for fitting
If you are interested, then send myself (Maverick) or Riccy (owner of Ulysess) a Direct Message or send a main to This email address is being protected from spambots. You need JavaScript enabled to view it.
A PDF file of the above is attached.
Thanks,
Brett Dukes (Maverick) and Richard Gifford (Riccy)
1x tube RTV sealant
1x Fitting Guide
Thanks,
Jalapeño, IISY?
Last edit: 01 Nov 2023 12:28 by mlines. Reason: edits
31 Aug 2021 16:29 #238069
Replied by Riccy on topic Jimny Gen3 Rear Fully Floating Rear Axle Kit - Advert approved by Martin Lines
The following user(s) said Thank You: maverick
31 Aug 2021 17:06 #238070
And pics of the custom HD shafts as promised:
Any feedback from anyone with our kit so far would be appreciated here and questions are welcome
- Thank you received: 1795
31 Aug 2021 17:55 #238072
Replied by Lambert on topic Jimny Gen3 Rear Fully Floating Rear Axle Kit - Advert approved by Martin Lines
Good work guys! If I ever start using rear bearings regularly I will be after a kit.
- Roger Fairclough
- Thank you received: 210
31 Aug 2021 19:36 #238077
by Roger Fairclough
Replied by Roger Fairclough on topic Jimny Gen3 Rear Fully Floating Rear Axle Kit - Advert approved by Martin Lines
OK I'm sitting down, how much and will it fit a Gen.4.
Roger
Roger
31 Aug 2021 19:41 #238078
by maverick
Jalapeño, IISY?
Replied by maverick on topic Jimny Gen3 Rear Fully Floating Rear Axle Kit - Advert approved by Martin Lines
At present this will NOT fit a Gen-4 which is why it’s advertised for a Gen-3.
It will fit a Gen-4 if and when we discover the actual length of the rear shafts
I will not openly discuss prices on the Forum. Send me a Direct Message if you interested in a purchase
Jalapeño, IISY?
01 Sep 2021 10:48 #238108
by maverick
Jalapeño, IISY?
Roger, if you want to get both your shafts out and acurately measure them from the Diff end to the Wheel Hub end, that would be excellent - then we can get the shafts made for a Gen-4.
Jalapeño, IISY?
17 Sep 2021 12:45 #238721
by maverick
Jalapeño, IISY?
Our first customer has bought 2 sets.
Jalapeño, IISY?
- Thank you received: 305
17 Sep 2021 19:57 #238732
by sniper
Replied by sniper on topic Jimny Gen3 Rear Fully Floating Rear Axle Kit - Advert approved by Martin Lines
Well done to you both.....
sniper
sniper
18 Sep 2021 04:57 #238740
Good news, hopefully the first of many!
11 Oct 2021 14:58 #239310
by maverick
Jalapeño, IISY?
We have agreed to add "pricing".
£800 plus postage for The Full kit which comprises:
a Pair of Alloy Adapter Plates, with all necessary bolts and Oil Seals
a Pair of "400BHP Rated" HD Floating Axles Shafts
We can supply Allen Head Bolts for suggested Jimny Vacuum Hubs for the kit at £13
As yet, it is only for a Jimny Gen-3 to make the shafts for a Gen-4, we need a volunteer to remove the shafts to get an accurate measurement of the shafts and then our shaft supplier can make us Gen-4 Shafts too.
Jalapeño, IISY?
17 Nov 2021 13:46 #240154
by maverick
Jalapeño, IISY?
Hello,
We are getting asked quite often now for a Jimny Gen-4 version for our Gen-3 Rear Floating Axle (strangely mainly from "down under").
If anyne who has a Jimny Gen-4 and would consider being our Guines Pig to test things out - of course the benefit for you is that we would give you a kit (Shafts and Adapter Plate) for free as part of the development.
Firstly, we need to have the rear shafts correctly measured, then the Rear ABS and Traction Control Sensor.
1) Measure Shafts:
To measure the rear shafts we would want the dimensions from end to flange face to compare with Gen-3 parts that we have. It will need to be measured as accurately as possible and as square as possible. Also some photos of how it was measured would be handy to ensure we work the same way on either side of the planet.
2) Re the ABS sensor setup:
With the floating rear you use the front abs sensors and trigger ring as you are aware. These sensors are a basic Hall effect sensor and simply rely on a tooth passing to generate a signal, which is why they are no issue on the Gen-3. There are more teeth and bigger gaps because it’s diameter is larger. This doesn’t seem to confuse the abs controller on the gen3, though it’s untested on the Gen-4 as yet obviously. Our only concern with the Gen-4 would be how it might affect the traction control, which presumably relies on the abs sensors to know what is happening.
Let me know, via an email to This email address is being protected from spambots. You need JavaScript enabled to view it.
1) Measure Shafts:
Jalapeño, IISY?
- Forum
- Suzuki Jimny
