Power Steering Conversion
30 Nov 2023 19:39 #252518 by lesgrandepotato
Interesting. Why do you say that?
30 Nov 2023 20:03 #252521 by jackonlyjack
Drop pitman arms can be really difficult to remove
also lowering angle pitman arms are not cheap
So i say cut drag link and weld in a thick plate making a z formation
just to see if it warrants spending on a lower angle drop pitman
30 Nov 2023 22:35 #252523 by lesgrandepotato
Ok I get you. I’ve got a drop arm here. I’ll see if the original will pull or not. It seems to be FT
01 Dec 2023 04:34 #252527 by fordem
Replied by fordem on topic Power Steering Conversion
A "Z-bar" will not have the same effect as a drop pitman arm - the pivot points remain unchanged, all it will do for you is allow the drag link to not foul on the leaf spring (if that is a problem).
Time to create page: 0.262 seconds
