Wiring for fog light switch…
- lesgrandepotato
- Elite Member
- Thank you received: 57
29 Aug 2023 15:29 #250571
by lesgrandepotato
Wiring for fog light switch… was created by lesgrandepotato
I’ve found a switch! I’ve converted the reverse light cluster on the Chinese tail lamp sets.
I’ve got a few potential wires (4) and a switch with 4 connections so this bodes well apart from the complete absense of any info of how it’s wired up! Anyone got a diagram for a 92 Spanish Sami? I’m sure given many hours it can be worked out. But a diagram is much easier!
30 Aug 2023 07:01 #250574
Replied by yakuza on topic Wiring for fog light switch…
On all my SJ and Sammys the extra switch on the dash controls power to the wire/plug ending up behind the driver side (Norway) rear lamp, often hanging down where the rear fog lamp used to be. Most often there is a bracket but lamp long gone as it hangs down into the snow drifts or terrain.
Found this:
forum.suzukiclubuk.co.uk/download/file.p...417097ec8d&mode=view
But fog light wire going back has a confusing color code on it. Still it is the same as on the swiitch in the dash so should be possible to separate and identify if found.
Found this:
30 Aug 2023 08:50 - 30 Aug 2023 10:34 #250575
by tomcat
Replied by tomcat on topic Wiring for fog light switch…
For the wiring on my Santana Samurai I had reference to the same wiring diagram.
I think you will find it is a yellow wire with green tracer plus a green marker tab on it. Hence the GYG.
Not 100% sure though.
Last edit: 30 Aug 2023 10:34 by tomcat.
- lesgrandepotato
- Elite Member
30 Aug 2023 09:29 #250576
by lesgrandepotato
Replied by lesgrandepotato on topic Wiring for fog light switch…
Cheers gents!
The mystery is unraveling…. I understand the white is ‘hot’ grey green yellow is to the lamp.
So the rest must be a relay to interlock with the headlights being on… so probably that’s the red or red and yellow..
Time to create page: 0.283 seconds
