diesel vitaras
  • Baloo
12 Sep 2021 06:32 #238505 by Baloo
diesel vitaras was created by Baloo
are there any vitara gurus on here ?  what  i would like to know  about is the bellhousing bolt patten on a diesel vitara,  i have a vitara with a deceased diesel engine which is the hdi pug engine  would the earlier pug engine the 1.9 from a 306 etc bolt up to the gearbox  ie does the hdi use the same block  ???     anyone ?
thanks Andy
13 Sep 2021 07:42 - 13 Sep 2021 07:44 #238539 by yakuza
Replied by yakuza on topic diesel vitaras
Not sure what year models in question here but other Suzukis that use these french engines do have the standard french bolt patterns and can use same engines from other makes.
That is more or less the point of using the standard french engines, if they use it as is then the price of them is cheaper for suzuki.
edit: I would try to use the same engine code and year of manufacture to make sure there is less other problems with the fit though.
Last edit: 13 Sep 2021 07:44 by yakuza.
  • Baloo
13 Sep 2021 17:34 - 13 Sep 2021 18:00 #238566 by Baloo
Replied by Baloo on topic diesel vitaras
hi
   sorry yes should have said the year.  think it was an 04 plate,  its the common rail hdi peugeot  but the last thing i want to do is use another one  its the third  one ive had fail. AA said it was the immboliser  refused to look at it and transported me 250 miles back home instead,   i have a perfectly good peugeot 306 diesel engine that requires 1 wire to make the injector pump work and no immboliser    yippee
sure i can make some sort of toy out of this
[img
Last edit: 13 Sep 2021 18:00 by Baloo.
  • Dirtbird
15 Sep 2021 07:44 #238625 by Dirtbird
Replied by Dirtbird on topic diesel vitaras
Baloo is there alot of modification to get the 306 engine to sit in the chassis?
  • Baloo
15 Sep 2021 17:44 - 15 Sep 2021 17:44 #238640 by Baloo
hi Dirtbird
in which chassis ?   but the answer is it fits in both the jimny and vitara easily with no chassis mods,  i still have a vitara with a factory fitted diesel engine  the XUD  as fitted to  205's 305' 405' etc   it was suzukis answer to a diesel vitara,  when it moved onto the grand vitara they used the mazda diesel the RF engine for a while  then they went back to the pug  common rail diesel engine engine.   and i used to have a diesel jimny with the xud engine which they fit as standard is some markets,  so its an easy fit
Last edit: 15 Sep 2021 17:44 by Baloo.
  • Dirtbird
15 Sep 2021 18:38 #238643 by Dirtbird
hi Dirtbird
Pure Gold Baloo thanks for the info  fella.
