Radiator Cover for the winter - is there one pls
06 Oct 2015 20:40 #153130
by Rhinoman
There is no mass flow meter on a 4u2, in any case a mass flow meter only controls fuelling not coolant temperature. The coolant temperature on the 4u2 is controlled primarily by the thermostat and the radiator.
Replied by Rhinoman on topic Radiator Cover for the winter - is there one pls
streetfighterjeff wrote: the mass flow meter does it all for you.
jeff
- Invicta
06 Oct 2015 21:09 #153132
by Invicta
Replied by Invicta on topic Radiator Cover for the winter - is there one pls
I'll take a look after I start it up tomorrow.
Thanks again for your advice,
Bern
Bern
- Invicta
07 Oct 2015 18:29 #153176
by Invicta
Rhinoman,
The top hose from the thermostat to the radiator warms up slowly from cold eg there wasn't a sudden change in temperature.
I couldn't see water circulating as I took the rad cap off the water level was half way up the neck of the short neck that the cap fits on. When I started the engine the water gradually started to expand and slightly spill over as it got warmer. I assume that was caused by the air in the water expanding.
Just a thought. Should the cold water level be so high?
I thought it was supposed to just be above the top of the internal fins?
I would appreciate your thoughts,
Been
Been
08 Oct 2015 16:13 #153225
by Rhinoman
I think that's OK, from what I remember the remote reservoir is higher than the rad cap
The following user(s) said Thank You: Invicta
- Invicta
08 Oct 2015 20:21 #153248
by Invicta
I'll check the level of the reservoir tomorrow.
Thanks again,
Bern
Thanks again,
Bern
Time to create page: 0.389 seconds
