Radiator Cover for the winter - is there one pls
  • Invicta
05 Oct 2015 15:48 #153030 by Invicta
My 2000 1.6 Vitara 4U tends to run cool.
(That's the water/engine temperature rather than a fashion statement)
So for the winter I am thinking of putting a cover over the front slats like the old Landies used to have.
Is there such a thing for Vitaras?
If not what material would people recommend I use please?.
My youngest son told me he had some radiator foil which sounded just the job.
I was going to tuck this in front of the top part of the radiator before I noticed it has plastic bubble wrap on one side. (it was for domestic/house radiators).
Any help will be much appreciated,
Bern
05 Oct 2015 19:02 #153058 by Rhinoman
What temperature is it running at? it should be around 88C under normal running. I never had an issue, have you checked that the thermostat is working correctly?
The following user(s) said Thank You: Invicta
05 Oct 2015 19:10 #153061 by jackonlyjack
in the past iv'e used corrugated card covered in kitchen foil
and keep cutting holes to reach desired temp ;)
  • streetfighterjeff
05 Oct 2015 20:11 #153071 by streetfighterjeff
Replied by streetfighterjeff on topic Radiator Cover for the winter - is there one pls
tbh dont think moden cars need a rad cover. back in the day when you had a lad for hot and cold weather, yeah ( i am tht old and i have merostly driven classics) but wower?? days you dont need them , the mass flow meter does it all for you. like a previous poster said check your thermostat.
jeff
  • Invicta
05 Oct 2015 20:41 #153072 by Invicta
Thank you for the replies.
I'm not sure what the actual temperature is.
The gauge barely goes above the C on the dial except when in very slow moving traffic when it goes up to around 1/4. (Hope that makes sense).
How do I tell what the water temperature is when the engine has warmed up?
The previous owner had replaced the radiator allegedly due to getting something in the fins so I could be starting on an interesting fault finding exercise e.g. Has it got the right thermostat fitted, etc.
As I haven't yet had time to investigate the cause in the cool running at this stage I am looking for a simple work around as my 4U is my daily drive.
Just as I am on the topic of engine temperature -
At one stage my old Mitsubishi J26 Jeep started to run very hot. It was due to the timing being miles out after it was "serviced" by a bunch of monkeys (no offense to Monkeys).
They nearly convinced me to fit a second cooling fan due to air being "trapped" by the big engine lump and causing lack of flow. It was only the fact that the engine was built to military spec and a neighbour (ex REME) had a strobe gun that I didn't go down the twin fan route.
I might suffer from trapped wind but the J26 didn't.
Bern
06 Oct 2015 20:38 #153129 by Rhinoman
You can measure the temperature with an IR thermometer at the thermostat or using a scan tool. When you start it up from cold is there water circulating around the radiator? you should be able to see that with the rad cap off.
