Blue is best.
- Thank you received: 667
10 Nov 2025 23:04 #262679
Replied by DrRobin on topic Blue is best.
I agree with all of the previous comments regarding driving through water, but I have done a few crossings in my Gen 4 over the last 2 years, all with a snorkel fitted and nearly all with the breather kit. A couple have been up to the headlights and I haven’t had any water ingress anywhere or any other issues.
I have done most in 4WD and the deeper/longer in 4WD-L, keep the clutch out all of the time, take it steady and make sure the revs don’t drop to avoid a stall.
This is Busk Lane near Stalling Busk (near Hawes, Yorkshire) last year, it’s quite a long lane and the depth is fairly even, although the flow/current is quite low.
Robin
Robin
11 Nov 2025 17:44 #262682
by KFP
2024 LCV in Brisk Blue.
Falken 215/75/15 tyres on Suzuki alloys.
Rear speakers & AUX cable.
Bilstein shocks with H&R springs.
Replied by KFP on topic Blue is best.
My driving/fog lights were definitely underwater on 3 of the half dozen crossings we did my mate waded all of the crossings in his wellies and only one did his socks get wet.
04 Jan 2026 20:37 #263266
by KFP
06 Jan 2026 13:07 #263299
by lightning
Replied by lightning on topic Blue is best.
l didn't realise the Jimny only has a 12" wading depth.
My 2022 Defender had a maximum wading depth of just under a metre. l wouldn't like to test it out, although l've seen Youtube videos.
The problem is, if you stall in water that deep there's a good chance your vehicle will be a write off.
Okay for motoring journalists maybe.
06 Jan 2026 13:28 #263300
by LM42
Replied by LM42 on topic Blue is best.
My local river crossing, "carwash" all that was lost was a plastic side trim
06 Jan 2026 18:03 #263309
It’s fine if you have a snorkel, the only things to worry about then are
the diff and TC breathers (which are 300mm) although should seal, but might let a little in if they were hot/open when you entered the water
the ignition coils might cut out, but with an engine up to temperature, there will be a lot of steam under there rather than water
the ECU, but if you are not there long, water won’t have chance to get in.
Time to create page: 0.224 seconds
