Re:Re:Re:Re:Re:Re:My Jimny gen4 South Africa mods/build thread
17 Aug 2021 09:49 #237638 by saxj
saxj wrote: There are a few guys who have already received their adjustable panhard rods from Des Sol. I unfortunately had to replace my rear one with an OEM one, just before the Des Sol ones became available.
That is not good news.
I was supposed to be in front of the line at dessol. :)
Maybe time to start looking into other options.
There are a few that have helped Des Sol with R&D, and they get pre production versions. e.g. I assisted with the design of the headlight levelling bracket, so consequently I had one to test before it became a production item.
The following user(s) said Thank You: lookonimages
  • MrPaynterZA
17 Aug 2021 11:02 #237645 by MrPaynterZA
Replied by MrPaynterZA on topic My Jimny gen4 South Africa mods/build thread
That's interesting, I didn't realise I'd need to update the panhard rods.
I don't think it's pedantic to want the vehicle to be right at all, and I will definitely be looking into that.
When I drop my vehicle off for the fitment, I will ask about the rods and see what the feedback is.
17 Aug 2021 11:44 - 17 Aug 2021 11:59 #237650 by lookonimages
MrPaynterZA wrote: That's interesting, I didn't realise I'd need to update the panhard rods.
Lifting a vehicle 50mm will alter the wheels position in relation to the body. To virtually see what I mean. Vehicle setup is like triangle with same volume. Changing one point will alter another. Eg pic below. Move A higher will shorten the vertical line point B.Therefore your wheels will move a little away from centre line. Many people dont mind and dont fit adjustable panhard bar to bring wheels back to centre.
I however want everything to be back to square so only way to do is to lengthen the pandard bar to get point B back to its original spot after point A moved higher.
On my jimny the lift also introduced the steering wheel to sit ever so slightly off centre and when wheels alugnment to body go back to zero, the steering wheel will sit perfectly straight again.
When measuring the wheels seen from top of wheel wells it is clear that wheels is 5mm more to one side.
Hugely exaggerated. wheels alignment to body
Last edit: 17 Aug 2021 11:59 by lookonimages.
  • MrPaynterZA
17 Aug 2021 12:28 #237652 by MrPaynterZA
Ah this makes sense, thank you for taking the time to explain it!
I would definitely also be interested in getting my vehicle back to square.
17 Aug 2021 12:42 - 17 Aug 2021 12:45 #237654 by lookonimages
MrPaynterZA wrote: Ah this makes sense, thank you for taking the time to explain it!
Again many people do not feel the need to make the correction as it is mm's that wheels move. It definately is not a prerequisite for a 50mm lift.
But there are a few who wants this to be corrected however slight it is and therefore the market for adjustable panhard rods.
You will see all big lift companies make it available like "Tough dog", "Old man Emu" and "Ironman4x4"
All personal taste. Only reason I have not yet fitted is I like to support local and was waiting for Des sol.
Last edit: 17 Aug 2021 12:45 by lookonimages.
17 Aug 2021 16:18 #237666 by Roger Fairclough
Before you splash out on adjustable Panhard rods, do you actually need them?
I have a 50mm lift and a quick check indicated no difference left to right so no need for expensive adj. rods.
Roger
Time to create page: 0.293 seconds
