Re:Re:Re:Re:Re:Re:My Jimny gen4 South Africa mods/build thread
- Thank you received: 667
16 Feb 2022 18:00 #241880
Replied by DrRobin on topic Re:Re:Re:Re:Re:My Jimny gen4 South Africa mods/build thread
That's a very smart front bumper, it looks great and wouldn't look out of place without a lift kit and on [fairly] standard tyres.
- lookonimages
- Thank you received: 72
16 Feb 2022 20:15 #241881
by lookonimages
Replied by lookonimages on topic Re:Re:Re:Re:Re:My Jimny gen4 South Africa mods/build thread
what I love is that there is NOT one hole to be drilled. IT FULL BOLT ON using excisting sructures of std bumper fitment areas.
have I told you that I am so happy with the bumper. man they have thought about every bloody thing
- lookonimages
23 Feb 2022 10:38 - 23 Feb 2022 11:03 #241995
by lookonimages
update on the "enhancement" I made to the bumper is as follows.
please excuse the work in progress pics. Currentky awaiting plates to be powder coated. the final product will look much better. these pics are not the final installation, but merely to give an illustration of the additional bracket
reason for change.
the bumper only really attach to body with 6 bolts. 3 a side. It do wrap around front chassis points, and current design seem to be very very strong. I however had a previous winchplate installed from jimnybits that also use the front cross member for more strength when winching and thus I decided to add that same concept to the dessol bumper.
It might be an overkill and infact not required at all, but I have a little time to play around
this is area where bracket will be installed.
this is the bracket I made to strengthen the winchplate. used the old jimnybits backplate of the previous winchplate.
this is where it attach bumper/winchplate to front cross member bar.
this is how it bolt on seen from below. bracket attach with 4 bolts to bumper and with two much bigger bolts to cross member bar. bolts is fastened with retaining plate on back side of the cross member bar.
this is the view from backside of cross member.
reason for change.
Last edit: 23 Feb 2022 11:03 by lookonimages.
23 Feb 2022 12:28 - 23 Feb 2022 12:30 #241998
by saxj
Replied by saxj on topic Re:Re:Re:Re:Re:My Jimny gen4 South Africa mods/build thread
That may give you peace of mind, but is totally unnecessary. I have done plenty of winching with mine, and the mounts are plenty strong enough.
I have also been towed out of some sticky spots. the recovery points are bomber.
Last edit: 23 Feb 2022 12:30 by saxj.
- lookonimages
23 Feb 2022 13:44 #241999
by lookonimages
great video btw.
Replied by lookonimages on topic Re:Re:Re:Re:Re:Re:My Jimny gen4 South Africa mods/build thread
yes I know I can be at times be complicating things. as said in my post I know it is not required and I know the kind of 4x4 you do, so yes it has been tested in the hardest 4x4 environment. "Kerkenberg" comes to mind.saxj wrote: That may give you peace of mind, but is totally unnecessary. I have done plenty of winching with mine, and the mounts are plenty strong enough.
great video btw.
23 Feb 2022 17:17 #242001
by saxj
Replied by saxj on topic Re:Re:Re:Re:Re:Re:My Jimny gen4 South Africa mods/build thread
That bumper has also been rammed in to obstacles a number of times and hasn't budged one millimeter.
Des Sol had a pro make the video.
