Re:Re:Re:Re:Re:Re:My Jimny gen4 South Africa mods/build thread
- Barry silver SZ5
19 Oct 2020 17:17 #229298
by Barry silver SZ5
Replied by Barry silver SZ5 on topic My Jimny gen4 South Africa mods/build thread
So jealous , great pictures. Thanks
- lookonimages
- Thank you received: 72
05 Nov 2020 13:48 - 05 Nov 2020 14:42 #229711
by lookonimages
Replied by lookonimages on topic Re:My Jimny gen4 South Africa mods/build thread
Finally done with my front winch recovery point. Basically a towbar, just in the front.
This way I only load the winch if I go on a trip. The advantage is
- The winch is 99% of the time in the garage out of harms way and weather.
- Save a few kg's not having it installed permanently
- can recover myself backwards or forwards.
The winch is just for own recovery in emegency. No intention of playing with the big dogs. So the 4500 pound winch should be ample for own usage. Together with a snatch block it should be ample enough for my kind of offroad.
Last edit: 05 Nov 2020 14:42 by lookonimages.
05 Nov 2020 18:19 #229721
Replied by Soeley on topic My Jimny gen4 South Africa mods/build thread
That is a really neat solution there, have you got any pictures of the front mount without the bumper in place?
- lookonimages
06 Nov 2020 06:50 - 06 Nov 2020 07:05 #229731
by lookonimages
Soeley
Well i had the jimnybits winch plate that is very solid and thought I will use it as the base plate. Not ideal though and if I did not have the winch plate I would have build it a bit different so tube sits directly on horizontal plate. Meaning a solid steel plate that ran on the top side of jimnybits side brackets (jimnybits brackets turned upside down) that would make the need for a " lift" obsolete. The only downside is you will loose the plastic bit then that direct airflow into radiator.
Base is rectangular tube 120x60x8mm
The sides for base is angle iron 60x90x8mm
The tube on top is 63x63x5.7 i think.
Top tube reinforced with flatbar 70x7mm
The front of tube reinforced with 8x8 solid bar to ensure mouth do not bend open.
The jimnybits winch bar.
I then cutoff the front lip.
Then I added the 50x10mm flatbar to inforce the flat section of jimny bits winch plate.
Cut slot in plastic air flow section so it fit over the "tow bar" bracket and still able to make it look nice as the airflow plastic piece also hide chassis / cross member.
Cut the slot in the bumper mesh so that top tube protrude through it.
Last edit: 06 Nov 2020 07:05 by lookonimages.
- lookonimages
06 Nov 2020 07:25 - 06 Nov 2020 08:02 #229732
by lookonimages
Will go test it the weekend but i am sure there is a lot that will fail before the tow bracket will fail. Build to be used for own winch recovery only. But it is ample strong.
Still need to add proper recovery point if someone need to snatch recover me.
But yeah i have to agree the jimny bits parts i ordered is exceptional quality and almost overkill in strength department but rather that then be sorry later. I was rather surprised when I opened the parcel from jimnybits winchplate. It is SOLID, you will comfortably be able to put 10000 pound winch on that winch plate. Recommended them anytime.
Last edit: 06 Nov 2020 08:02 by lookonimages.
The following user(s) said Thank You: PabloAzH
06 Nov 2020 08:10 #229733
Replied by Soeley on topic Re:My Jimny gen4 South Africa mods/build thread
Thanks for the extra info.
If you want the Jimnybits front recovery points, give them a ring/email eplain you have the winch plate and you should be able to buy the recovery points only. I asked about that before I bought mine and the points and winch plate are all interchangeable.
The following user(s) said Thank You: lookonimages
Time to create page: 0.228 seconds
