Re:Gadget's 2019 hearing aid SZ5
16 Mar 2019 19:54 - 16 Mar 2019 19:56 #204665 by Gadget
mikeyw85 wrote: nice write-up. i'm struggling to get hold of those parts. wish the availability over here was a a bit better.
Thanks, yes it's a pain in the bum that we can't get the full accessory selection as standard. I ordered them in from Japan, but the site I used (Japanparts.com) has removed them for some reason (plus it worked out to be silly money with shipping and customs).
JimJimny wrote: Thanks again for another great step-by-step. So how does it sound now ....and does the head unit allow you to adjust/fade the balance between the front and rear speakers?
Thanks. Sounds loads better than before. I thought the dual speaker setup sounded ok, but with my son in the back I had to turn the volume right up so that he could listen as well. The SZ5 headunit allows you to fade front/rear, I'd imagine the SZ4 does too, but not tried it.
Last edit: 16 Mar 2019 19:56 by Gadget.
16 Mar 2019 20:46 #204670 by Gadget
Probably needs removing on the left-hand side for parking sensors, camera and towbar electrics, as all of mine seem to be there!
The following user(s) said Thank You: facade
17 Mar 2019 06:07 #204672 by facade
Are the towbar electrics just plug in, or did they have to modify the harness?
If it is plug-in, I'll fit mine myself, if they have to ness with wires Suzuki will have to do it as I'm not having them refuse to sort out all those electronics that can go wrong because they can blame the failure on my fitting the electrics wrong.
  • pixelpower
17 Mar 2019 12:39 #204687 by pixelpower
Replied by pixelpower on topic Gadget's 2019 hearing aid SZ5
Do you know if 215 tyres will fit on the steel wheels of an SZ4? I'd like to change mine but not sure if I need new rims too.
  • mikeyw85
17 Mar 2019 13:03 #204688 by mikeyw85
Replied by mikeyw85 on topic Gadget's 2019 hearing aid SZ5
pixelpower wrote: Do you know if 215 tyres will fit on the steel wheels of an SZ4? I'd like to change mine but not sure if I need new rims too.
Yeah should do. I'm doing it within next week or so. I think 215 is about the limit for a 5.5" wheel, but it's ok.
www.lvvta.org.nz/documents/infosheets/LV...patibility_Guide.pdf
Scroll down to "Four wheel drive and SUV guide"
17 Mar 2019 17:35 #204698 by Gadget
facade wrote: Are the towbar electrics just plug in, or did they have to modify the harness?
I'm not sure, I had the dealer fit mine and it looks like a mass of wiring behind the trim panel.
Should be fine, steel wheels are the same width as the alloys.
Time to create page: 0.278 seconds
