Soeley's 2019 Black SZ5
03 Feb 2019 10:43 #202434
by saxj
Replied by saxj on topic Soeley's 2019 Black SZ5
Is the rubber mat a Suzuki Accessory. If so, do you have a part number.
- Thank you received: 622
03 Feb 2019 15:57 #202446
Replied by Soeley on topic Soeley's 2019 Black SZ5
03 Feb 2019 16:11 #202448
Replied by mlines on topic Soeley's 2019 Black SZ5
990E0-78R30 - £65 from BigJimny Store
The following user(s) said Thank You: Gadget
03 Feb 2019 16:16 #202449
by saxj
Thanks, but I think with shipping from the UK, it may end up costing quite a bit more than buying locally.
mlines wrote: 990E0-78R30 - £65 from BigJimny Store
16 Feb 2019 17:17 #203326
I upgraded my reversing light bulb yesterday to an LED item. It is much brighter and seem s to give a better light spread. I got it from
Autobulbs
Standard
LED
Standard
LED
16 Feb 2019 17:28 #203327
I have been having a play at making my own mudflaps. I just think the genuine Suzuki one are a bit extortionate! These are universal blanks from Demon Tweaks £19.20 for a pair.
Not sure whether to trim the width down a bit on the inside so that they cover the tyre width evenly, and do I leave the corners square or round them off slightly?
The white plastic L section will get a coating of black and will in due course be replaced with some ally.
Two spire clips used in original fitment holes, one L bracket for additional support and lower edge drilled just as per Suzuki fitting instructions. Black number plate screws used on the lower edge of the bumper.
The plastic reinforcing strip will be replaced with some ally sheet cut to the same profile. Just stops the upper edge of the flap from flopping over.
Time to create page: 0.481 seconds
