Paras red 2002 jimny jlx
- Thank you received: 1839
29 Nov 2018 05:14 #198325
Replied by Lambert on topic Paras red 2002 jimny jlx
Ooh red, I like the red ones!
The following user(s) said Thank You: paradox1001
- paradox1001
- Visitor
29 Nov 2018 10:21 #198339
by paradox1001
Replied by paradox1001 on topic Re:Paras red 2002 jimny jlx
@Scimike
I’m really impressed with the tyres
Very little road noise from them and great wet grip on road
They performed brilliantly in the bad snow we had earlier in the year
I haven’t done any heavy off-roading with them but across grass fields,stoney gravel tracks and muddy verges they have been fine.
They are a night and day difference to the duellers the car came with.
They just don’t look as good as bfg all terrains or general grabbers.
- paradox1001
- Visitor
29 Nov 2018 10:24 #198341
by paradox1001
@max headroom
I can’t remember the make of the towbar only I bought it off eBay
It was fine with the exhaust that was in the car but when that rotted out and I fitted a new one
The new one was slightly longer and tapped on one of the towbar brackets.
I cured it by making a buffer from some rubber fuel hose with a cable tie running through the centre to fasten it to the bracket.
- paradox1001
- Visitor
29 Nov 2018 10:27 #198342
by paradox1001
@lambert
It’s not as red as it should be anymore
It’s going quite pink so needs a good going over with compound in the mop.
- Max Headroom
- Banned
- Thank you received: 217
29 Nov 2018 11:08 #198347
by Max Headroom
Replied by Max Headroom on topic Re:Paras red 2002 jimny jlx
Thanks for feedback, on your exhaust Para.
That's a good fix on the rattling if there was nothing else you could do; its exactly what I think I would have resorted to doing. I doubt it will chaffe through, but it might be worthwhile checking that rubber is still keeping the two apart; you wouldnt want a holy exhaust later.
For some reason red paint on most makes is quick to oxidise which is what is happening to yours.
Vauxhall had a huge problem with it. You will find a virtually endless amount of information on how best to 'correct' it on a site called Detailing World . Be awware there are many abbreviations used by detailers and you may find "LSP" commonly used with regards to oxidising - this just means "Last step product" meaning the last stuff you would apply.
Unfortunately once started you will need to reapply every few months.
There is a good example of info HERE where there are five pages of discussion culminating with some photos of the rectification at the end of the thread.
I note also there was product by Meguirs called "#7 Show Car Glaze" is said to have been produced specifically for this problem. Read the wole thread and follow the comments made there by someone there called Stangalang.
After that is all fixed you will need to seal it in using some good quality wax - its the wax that will need re-applying every so often.
Hope you find something there to help!
- paradox1001
- Visitor
29 Nov 2018 12:40 #198353
by paradox1001
The rubber pipe is doing fine
It shrank a little from the heat and became loose but I just repositioned it and tightened the cable tie up.
I’ll know if it’s chafed through as it will start knocking again.
Yeah the paints oxidised as I don’t think it been waxed for years.
I had a red fiesta xr2i years ago that was the same.
I’ll be using autoglym paint renovator,autoglym super resin then autoglym extra gloss with a da polisher when I get round to doing it.
I’ve used those products before to great effect and I’ve no doubt the will bring the Jimnys paint back to great condition.
I’ve treated the jimny to some new wiper blades today
Valeo for the front and Bosch for the rear as that’s what the motor factors had.
With new wipers and night breaker bulbs I now should be able to see where I’m going better.
