Szabi's Jimny
  • 1066Boy
  • Visitor
  • Visitor
09 Oct 2017 16:25 #185005 by 1066Boy
Replied by 1066Boy on topic Szabi's Jimny
Do you need spacers?
  • Szabek
  • Visitor
  • Visitor
09 Oct 2017 17:46 #185012 by Szabek
Replied by Szabek on topic Szabi's Jimny
Of course! :) Do you have some spare one?
09 Oct 2017 18:18 #185015 by Riccy
Replied by Riccy on topic Szabi's Jimny
I have +30mm bulldog spacers which seem pretty good. With 215/75r15 it needed trimming front arches only a bit . with 235/75r15 its catching on the front body mount under hard cornering only so not bad, that plus the 5.5" lift :-)
  • Szabek
  • Visitor
  • Visitor
17 Oct 2017 16:10 #185329 by Szabek
Thanks Riccy,
Is the Jimny was lifted already when you fitted the spacers with the 215/75s?
17 Oct 2017 17:13 #185334 by Riccy
When i first got the spacers it was with 2" trailmaster lift kit and 2" body lift but on the 215/75 tyres.
I think it might mean a bit of trimming of the front and back of the front wheel arches. never had a problem with the back (even with 235 tyres on 8" rims)
A side note is that you should expect a fair increase in spray and muck up the sides...
Also search a member called Ant0 (i think), who has spacers on his more standard jimny ;-)
The following user(s) said Thank You: Szabek
  • Szabek
  • Visitor
  • Visitor
28 Oct 2017 06:55 #185588 by Szabek
I got my MOT done yesterday. Quite happy with it. Inspector told me, car is mint and only front body mounts need some corrosion prevention, because surface rust started to show on them.
Any suggestion on this one? How do I treat them? Clean off the rust and paint it down or treat it with waxoyl?
28 Oct 2017 07:16 #185590 by Riccy
clean em up and paint on some buzzweld RCP (rust control primer) then CIO (chassis in one top coat). They do an aerosol spray cavity wax which is good for hard to reach places also.
While your at it take the headlights out and check behind them as thats usually a bad spot ;-)
Time to create page: 0.160 seconds
