Re:The Jimny of the Yakuza
08 May 2018 07:45 #192497 by yakuza
Replied by yakuza on topic Re:The Jimny of the Yakuza
New gearbox with new seal is leaking.
Or more correctly the drive shaft is leaking ref. this post: www.bigjimny.com/forum/7-jimny-technical...ain-grrrr.html#71942
the shaft is leaking inside the spline yoke. Seen some seal it with silicone.
I'll try to clean it with brake cleaner spray and seal it with Tec7.
So will start to find a drive shaft from a newer car if possible.
Not many of those here in Norway, I know of the car i got the gearbox from only.
08 May 2018 08:03 #192499 by yakuza
Ok so it could have been done with a regular car or a tractor but of course this is much more fun with a Jimny!
The dog and I fixing the horse track for the kids with a harrow..
  • OlaGB
09 May 2018 11:21 #192549 by OlaGB
Replied by OlaGB on topic Re:The Jimny of the Yakuza
yakuza wrote: Ok so it could have been done with a regular car or a tractor but of course this is much more fun with a Jimny!
Put it to work, not far from being a little tractor anyway!
That dog would probably pull that harrow too :D
09 May 2018 12:24 #192552 by yakuza
He should be capable to do that, but he is probably the most useless lump of protein in Western Norway. :)
29 May 2018 18:09 #193033 by yakuza
Bought some sort of Teflon tape off ebay and now my seat belts return quite good. The hanger was pretty dirty again so washing with brake cleaner did help too.
Sent fra min E5823 via Tapatalk
11 Jun 2018 09:25 #193369 by yakuza
Pulled my transfer box this weekend to change the gears. will post pictures later.
Found my synchronizer ring on the 4x4 front output had broken.
I must have done something stupid while trying to get the case back together that broke the ring, or it was broken before.
It was very troublesome to get the box together as well and i did not get it to shift properly so trying to order a new ring today.
So now I await my local Suzuki dealer and hoping it can be sourced within reasonable time.
Time to create page: 0.227 seconds
