Re:The Jimny of the Yakuza
08 Apr 2018 16:24 #191450 by yakuza
Replied by yakuza on topic Re:The Jimny of the Yakuza
So it's a write off.. See the missing tooth. And I need a strike of luck to find a new one in Norway. Sold less than 20 a year since 2010 I've heard.
Sent fra min E5823 via Tapatalk
08 Apr 2018 16:29 #191451 by yakuza
OlaGB wrote: I considered the same, running without changing high gears, but that will make me run alot more in 3rd and 4th gears, instead of in 1:1 5th gear.
Better or worse for the bearings? I would think worse..
On 29`s i think i will be only 200rpm higher @ 100km/h on my planned ratio, than on stock wheels/transmission. Probably just better off like that, since the wheels are heavy..
Had a look for R72 on bildelsbasen as well now, as i found my motor over in sweden through that page.. But none to be found, and even the R7me was kind of expensive over there.
Good luck diving into the box, it was pretty easy to split / rebuild :)
Agreed that it would be better for the r72 gearbox to gear down a bit.. I will dive into the grimjeeper calculator again tonight and try to make sense of the r7me swap and 235's.
  • OlaGB
08 Apr 2018 16:36 - 08 Apr 2018 16:37 #191452 by OlaGB
Replied by OlaGB on topic Re:The Jimny of the Yakuza
Baah thats not good news.. :(
Maybe the gear parts you need to rebuild, isnt all that expensive though.
Last edit: 08 Apr 2018 16:37 by OlaGB.
08 Apr 2018 17:12 #191453 by yakuza
could be but that is a last resort for me... If i get hold of a low milage 2010 or newer gearbox somewhere it would still be better and probably cost the same.
I did not bother to open anymore to see if there was more damage. kind of fed up today..
  • Daniel30
08 Apr 2018 17:43 #191455 by Daniel30
Replied by Daniel30 on topic Re:The Jimny of the Yakuza
I feel your pain :( just changed mine
08 Apr 2018 20:33 #191463 by kirkynut
Replied by kirkynut on topic Re:The Jimny of the Yakuza
This is horrible for you. I'm so sorry to hear the damage is so bad. You're right to look for another box, new gears in that box will whine when run with old worn gears due to the wear pattern on the old gears.
Time to create page: 0.466 seconds
