My Jimny named R&B
Topic Author
- Thank you received: 687
05 Nov 2016 13:14 #174259
Mmmm i like prototypes Keithy pm me some piccy's
Replied by jackonlyjack on topic door card modification
Keithy wrote:
Heyup Jack, how is the "armrest" fabric held on?jackonlyjack wrote: i have a couple of reasons why i did it
1 being short
2 the bucket seats
will put template to one side just in case someone ask's for it
Jack
I'm wanting to raise mine as the arm out of the window season is over.
I'm contemplating making some door pockets which could actually hold something more than a slip of paper..Possibly a beverage of some kind...I'll wager you'd be brave enough to fit some, want me to save some prototypes for you?
Topic Author
05 Nov 2016 13:19 - 05 Nov 2016 13:21 #174260
More RCPing today done all inside the rear body cavity
i did not realise there was so many places for water to ingress
till all the paint started to run out :ohmy:
Jack
Jack
Last edit: 05 Nov 2016 13:21 by jackonlyjack.
Topic Author
12 Nov 2016 17:16 #174544
Replied by jackonlyjack on topic New back box
- Gazguzzler
12 Nov 2016 21:50 #174553
by Gazguzzler
Replied by Gazguzzler on topic New back box
That looks good and very neat, any photos of what it looked like premod, or what you had to do it mod it to fit?
Phil
Phil
Topic Author
12 Nov 2016 22:31 #174555
The main reason for using the savvy pipe
Is it has these on each end
I shortened it a little and already had a tight 1D 90degree bend wasn't to much of a job
Not to sure whether i like the exhaust note
it's not stupid loud
Ebay item number 291940019493
I cut the flange off bent long end
Then welded it to the short straight before the box
Other end i cut off see picture
That will be used on my next silencer if i chose to remove the one fitted
Jack
Jack
Topic Author
17 Apr 2017 12:41 #180332
Replied by jackonlyjack on topic Transformation begins
so i opted for a 1" body lift
main reason is for cleaning the under side
not leaving any trapped mud and better air flow round body mounts to dry them
body mounts have minimal rust
but gave them a scrape painted with buzzweld CIO
lifting the front was a bit un nerving (never done this before)
Time to create page: 0.317 seconds
