My Jimny named Grin Giver
03 Aug 2018 15:52 #194813
by sniper
Replied by sniper on topic My Jimny named R&B
R&B looks well with them on pal, a bit of grinding and a bit of welding.....
It looks quite easy to triangulate / support the mount and allow you to cut away the projection, what an MOT inspector will say I don't know.... I can cut and prep the plates but can't weld anymore. Local garage will weld it for £80 if needed, they are testers too so I can have a word about welding around the mount, again if needed.
sniper
sniper
03 Aug 2018 16:46 #194814
Replied by Riccy on topic My Jimny named R&B
I put a ratchet strap around the body mount's two sections and squeezed them together a bit (maybe 1" all together).
Also installed some sexy rockwatt extended bump stops, which seemed to help just as much with the same problem.
What size are they? look great on the GV rims
Topic Author
03 Aug 2018 20:01 #194816
Replied by jackonlyjack on topic My Jimny named R&B
225 75 16 i also have rockwatt bump stops fitted too
04 Aug 2018 06:12 #194819
so thats a 29.3" tall by 8.9" wide tyre then, compared to the 31x10.5 i have, i am surprised you have a problem with them catching.
Different rims, offset and lift maybe? for reference my rims are 15x8 et -0, theres 30mm wheel spacers and 4.5" lift on the springs
Topic Author
04 Aug 2018 07:13 #194820
Could be that i have 3" castor arms with a 2" lift. Therfore the axle is pushed forwards
Being over casterd it drives so nice
I have got 4 Honda crv springs so i can go up some
04 Aug 2018 07:46 #194821
That will explain it then! I too have 3" castor arms, which will be pulled back by inference then
Time to create page: 0.217 seconds
