Fitting snorkel
- kanew
29 Dec 2015 16:05 #159295
by kanew
Fitting snorkel was created by kanew
Needing a bit of help from the vetrans!
Ive had my jimny for a couple of months now but recently been hit by the floods.
Im only one in the family with a 4x4 so i've been doing some deepish wading up to around the headlights.
ive been checking air filter and diff oils n stuff to make sure theyre all good to go but now im wanting to add a snorkel and some breathers but i've hit a snag.
The car has a cone filter and a larger than standard battery which half covers the hole for snorkel.
Im thinking of sticking battery to passenger side and just extending the cables so i can get the snorkel on.
But how the hell do I connect snorkel now with this cone filter, will I have to get a new filter box from breakers or is there another way of fitting it.
any help is much appreciated!
- kanew
29 Dec 2015 16:13 #159296
by kanew
Replied by kanew on topic Fitting snorkel
- GraphicX
30 Dec 2015 11:34 #159344
by GraphicX
Replied by GraphicX on topic Fitting snorkel
bit of a headache for you having someone who's thought they're improving the car with the bigger battery & crappy pod filter, but they've actually done the opposite.
i honestly think your best option would be to get the original air box & plumbing again, the battery would then have to be moved or replaced with one of a standard size.
other alternative would be to either make or have made a custom snorkel which would become pretty expensive compared to the cheap ebay units.
wading in water at the depth you're speaking about 'should' be pretty safe so long as you keep moving forward though, your car will create a bit of a bow wave & the water should flood up to the filter. but if any does that filter is sure to suck it down quick.
- kanew
30 Dec 2015 14:16 #159349
by kanew
Ah I thought that might be the case :dry:
I'll have to have a look at getting an air box from somewhere.
Battery is an easy enough job but still a pain in the ar** when I shouldnt have to do it in first place!
The only off roading I do is only around shooting estates and stuff so I dont need a beast for mud but with the recent floods I want to get car to the point where it can go through almost any flooded road. All defenders and rangerovers are getting abandoned in ponds at min, although half of em dont know how to drive so probably more workman trouble than tool trouble!
- Thank you received: 706
30 Dec 2015 19:24 #159358
Replied by jackonlyjack on topic Fitting snorkel
The following user(s) said Thank You: kanew
Time to create page: 0.107 seconds
