I fitted and outside temp sensor today
  • NineCherries
11 Feb 2015 22:27 #137651 by NineCherries
Replied by NineCherries on topic I fitted and outside temp sensor today
Linky to eBay temp sensor item 261536268671
261536268671 just in case the above link doesn't work, this is the one I got.
Only issue is if I change away from this radio to a double din unit I'll need to find a new location for it lol.
  • Zee Zee Top
12 Feb 2015 13:26 #137683 by Zee Zee Top
Replied by Zee Zee Top on topic I fitted and outside temp sensor today
thanks for the link.
12 Feb 2015 15:26 #137691 by Halford
thanks NineCherries, cheap as chips ;)
just curious as to whether anyone knows where most car temp sensors are actually fitted ?
how does the mirror assembly actually come to bits ?
  • GuardianAngel
12 Feb 2015 17:43 #137700 by GuardianAngel
Replied by GuardianAngel on topic I fitted and outside temp sensor today
Tadpole wrote: Here's the one I fitted ........... ;)
Where did you get this one from?
  • Tadpole
12 Feb 2015 19:12 #137724 by Tadpole
Replied by Tadpole on topic I fitted and outside temp sensor today
No eBay APP ID and/or Cert ID defined in Kunena configurationFrom ebay there others the same in the uk item #231104378490 hth .......... ;)
I like this type as it shows the battery charge, the sensor I threaded below the carpet & stuck it to the door hinge seems to work well & is protected from knocking .. :whistle:
  • Statey
13 Feb 2015 23:00 #137849 by Statey
Replied by Statey on topic Re:I fitted and outside temp sensor today
Did you hard wire it in??
Time to create page: 0.196 seconds
