Galactic Jimny
- OllieNZ
- Visitor
- Visitor
- jim
- Visitor
Daniel30 wrote: Neat and tidy job
Thanks Daniel30 I enjoy doing little jobs like that. Don't think il run out of things to do on a Jimny there's just always something.
- jim
- Visitor
OllieNZ wrote: Leads don't last forever, I've recently changed mine due to leakage. It can be quite hard to spot but you can get testers for them.
- OllieNZ
- Visitor
That could have been nasty, those little blighters chew through everything......jim wrote: I had a lead go before, turned out rats had been nesting in the engine bay! Luckily it was just the leads.
- jim
- Visitor
New Brembo pads and discs went on, two new aux belts after spotting the old ones were cracking. Re greased the caliper sliders as they are known to seize.
Track rod ends one was slightly leaking grease but had no play so replaced them and the faint wobble at 50 has gone its true they may not seem worn but can be.
Replaced the propshaft with a known non leaking one I noticed since replacing the oil seal last time it hasn't used much oil. Hopefully now it won't leak any.
Fitted a small in car thermometer from China just what I've been after for a while. I like to know if it's below 5 degrees Celsius to drive even more cautiously in case of ice.
All in time for Cornwall
- jim
- Visitor
- jim
- Visitor
- new caliper seals for o/s caliper
[strike]- non a/c belt to bypass the a/c pump[/strike]
- [strike]gearbox oil change [/strike]
[strike]transfer box oil change[/strike]
[strike]- front tyres[/strike]
[strike]- underseal[/strike]
- wheel spacers
thats all the fluids changed for this year. I might try some 30mm cnc alluminium wheel spacers next
- jim
- Visitor
Also,as one job is done another emerges, my jimmy has now got the intermittent power loss issue and I need to look at the cat or camshaft sensors.
To make me feel a bit better I won on ebay a used Suzuki dog guard with load liner. Ill post some pics once I have collected it.
- gusthegorilla
- Visitor
I recently won an identical dog guard from a Forum member in Holland, and someone pointed out that one you have soon after...good win, I'm delighted with mine, fits like a glove
Gus
- jim
- Visitor
- jim
- Visitor
I have used Granville rust converter instead of the Kurust that I have used before, apparently this stuff is used on oil rigs and it leaves a tough finish. I will also be spraying it in satin black.
At the same time I'll give the rear wiper arm a coat of paint as that has faded to an almost white colour.
New tyres have been ordered for the front, I went with my usual all terrain tyre with wet grip B rating.
www.tyreleader.co.uk/car-tyres/nexen/roa...r15c-104-102t-432975
Galactic Jimny passed its MOT with flying colours, no advisories.
