Dave's S200KYS Jimny
  • Statey
  • Visitor
  • Visitor
03 Nov 2015 22:08 #155293 by Statey
Replied by Statey on topic Dave's S200KYS Jimny
Is that a rear Fog light at the centre?
If so do you know the name im looking for something similar B)
  • Statey
  • Visitor
  • Visitor
03 Nov 2015 22:11 #155294 by Statey
Statey wrote: Is that a rear Fog light at the centre?
Just did a bit of digging and its a brake light... mmm wonder if it could be my fog light? :woohoo:
  • X8GGY
  • Platinum Member
  • Platinum Member
  • but currently AWOL
01 Jan 2016 16:50 - 01 Jan 2016 16:58 #159487 by X8GGY
Replied by X8GGY on topic Dave's S200KYS Jimny
Time again to get the spec' up to date...
'54 plate soft-top Jimny, hiding under the "S200KYS" personal plate
Suzuki rear hardtop section (front soft-top section retained)
JimnyBits +4" Diesel front springs on the rear, +4" front springs and Bits4Vits Spring Spacers on the front ~5" lift
Rockwatt Stainless Steel Adjustable Panhards (front one kinked to get round the Zanfi drop pitman arm)
Zanfi +80mm front panhard rod drop bracket (modified to fit a right-hand drive Jimny)
Zanfi +80mm rear panhard bracket
JimnyBits-sourced AVO adjustable +4" shock absorbers
Rockwatt's new Rear Bump Stop spacers and poly bump stop cones
JimnyBits anti-rollbar disconnect system
Rockwatt Heavy Duty steering bars
Rockwatt installed rear ARB Airlocker
Rockwatt installed front Calmini (Vitara) LSD machined to fit
RS-Mfg 26 spline front shafts and heavy duty CVs
Rockwatt Rocklobster Transfer Box (with two wheel drive low) and Bucket mount, with-
Speedo-ring to correct speedo for the-
Maxxis Trepador 31" x 10.5" tyres on JimnyBits 15" ET-30 offset Black Steel Modulars
Land Rover Defender +50mm wheel arches
Currently manual hubs, but would like to go back to vacuum hubs eventually
JimnyBits (ABS) Battery Tray with Odyssey PC1200 winch battery fed by T-Max split charge system
ORA front winch bumper with Warrior 8,000lb "High Speed" Winch, dashboard control
ORA rear bumper modified to fit round -
Rear Towbar adapted to take T-Max 9,500lb rear winch, dashboard and remote control
ORA 'flat-pack' roll hoop
ORA CAD-bent soft-top and rear fibreglass hard-top roof protection bars with -
Waffle Boards mounted on top (partly to protect the hard-top too)
My trusty old Cobra waterproof bucket seat
ARB compressor (for Airlocker) and tyre inflation line
JimnyBits rear disk brake conversion
ORA sill bars
JimnyBits rear shock guards
JimnyBits front shock guards
JimnyBits front diff guard
ORA radius arm guards
JimnyBits fuel tank guard
(Genuine) Safari Snorkel
BigJimny Breather Kit slightly modified to fit gearbox, transfer box and axles
Dash and handheld CBs
iPad with RAM mount running MemoryMap and TomTom SatNav (with Homer Simpsons voice!)
Front, Rear and inside work LED lights, all controlled from dash switch console
Hi-Lift Jack mounted across internal roll hoop
Ground Anchor behind driver's bucket seat
Strops, Shackles, Bridles, Ropes behind passenger seat
Saw, Axe, Bolt Cutters, Rigid Tow Pole behind spare wheel mounted on rollhoop stays
Tools and Spares in two tote boxes behind the spare
Cordless Bosch 36v Chainsaw
First Aid Kit and Fire Extinguisher
Still to do this year -
Front axle rebuild as I have a small oil leak from the diff to axle casing joint. All new bearings and seals whilst doing it. And new disks and pads.
Front Rockwatt Bump Stop Spacers (when they are released) with poly bump stop cones
Replacement 4.87:1 Transfer Box when it's built @ Rockwatt's
Front mudflaps to stop mud being thrown up the side and over the windows
New passenger seat for my 'laning buddy Alan
Last edit: 01 Jan 2016 16:58 by X8GGY.
  • Daniel30
  • Visitor
  • Visitor
01 Jan 2016 17:18 #159490 by Daniel30
Replied by Daniel30 on topic Dave's S200KYS Jimny
Well is that it then Dave!!!! Jesus!!!!! :laugh: :laugh: :laugh: :woohoo:
Got a seat for Alan what do you think? :whistle:
[IMG
02 Jan 2016 11:42 #159528 by Rhinoman
Replied by Rhinoman on topic Dave's S200KYS Jimny
Not at that height.
02 Jan 2016 17:37 #159545 by Busta
Replied by Busta on topic Dave's S200KYS Jimny
Any idea how much it now weighs Dave?
