Cherry red Jimny from Estonia
- Taavi85
- Visitor
27 May 2014 10:43 #116429
by Taavi85
Cherry red Jimny from Estonia was created by Taavi85
Greetings from Estonia. Because Estonian Suzuki forum is almost dead, I decided to join with BigJimny
I have thought about buying a 4x4 long time and so month ago i bought this red Jimny JLX.
Pic
So far i have found plenty of rust and stuck bolts....which is'nt a big suprise for Japanese cars but still a little bit buzzkill, at least the frame seems good.
What's gonna change?
At the moment i have already bought/changed/done:
1) New tyres - Insa Turbo Sahara 215/75-15" (waiting new rims from Jimnybits, because they were out of stock )
2) 2" lift kit - Pro Comp 2" from Jimnybits. Front end done....rear waiting.
3) 8000lbs DragonWinch - winch plate designed and cut, waiting at the moment for powder coating Pic 1 Pic 2 Pic 3
4) Poly bushes - got super cheap kit from eBay, from Poland (£114 inc. shipping). Let's see if they are any good
5) Removed sway bar
6) Longer brake hoses - because i removed the sway bar i think i should replace the brake hoses (?)
If i have 2" lift and removed sway bar should i replace only the front ones or also the rear? Can anyone tell me the length of extended front hoses?
Pic
5) Removed sway bar
- GuardianAngel
- Visitor
27 May 2014 11:23 #116434
by GuardianAngel
Replied by GuardianAngel on topic Cherry red Jimny from Estonia
Yes you do need to replace them. I dont know the length but the BJ shop sells them
- Tadpole
- Visitor
27 May 2014 18:32 #116463
by Tadpole
Replied by Tadpole on topic Cherry red Jimny from Estonia
Welcome our fine forum it’s good to have you join us ................
- jonathan
- Visitor
28 May 2014 19:40 #116556
by jonathan
Replied by jonathan on topic Cherry red Jimny from Estonia
welcome to the forum
- Bits4Vits
- Visitor
28 May 2014 20:26 #116559
by Bits4Vits
Replied by Bits4Vits on topic Cherry red Jimny from Estonia
Looking good... like the winch tray!
- Taavi85
- Visitor
10 Jun 2014 07:07 #117528
by Taavi85
Replied by Taavi85 on topic Cherry red Jimny from Estonia
Had some time and made rear shock repositioners:
Bits and pieces
Welded and painted
Mounted
Installed the winch to the winchplate...only wiring to go
Winch
Bits and pieces
Welded and painted
Mounted
Winch
- jtayl153
- Visitor
10 Jun 2014 15:47 #117560
by jtayl153
Replied by jtayl153 on topic Cherry red Jimny from Estonia
Very nice Jimny you've got there!
RE the brake lines. YES! Replace them.
With no lift and no sway bar, you're fine, but with 2" lift, and no sway bar you risk pulling a line on full articulation - and I'd know cause I tested it out with some hi-lift jacks.
- Taavi85
- Visitor
02 Aug 2014 08:51 #121229
by Taavi85
Finally got the wheels and tyres fitted. Winch is wired up and bigger 62Ah battery (Centra CP621).
Brake lines are changed.
Are the Jimny brakes originaly poor? Changed the rear shoes and front sliders (old ones were rusted), everything moves fine and no air in the system but braking is pretty poor....is this "normal" or should i inspect something else?
Pic 1
Pic 2
Pic 3
Pic 1
Pic 2
Pic 3
- Tadpole
- Visitor
02 Aug 2014 19:25 #121254
by Tadpole
She's looking good .........
- Taavi85
- Visitor
04 Aug 2014 12:38 #121333
by Taavi85
- Taavi85
- Visitor
18 Sep 2014 13:33 #124442
by Taavi85
- Tadpole
- Visitor
18 Sep 2014 18:58 #124469
by Tadpole
Looks like you had a lot of fun ....
